Page 66 of 68 FirstFirst ... 16566162636465666768 LastLast
Results 976 to 990 of 1006
  1. #976
    Member ECU2009's Avatar
    Jan 2016
    European Union
    guys please I need some information, I lexia 3 clone have a long time yet the version with two separate software Citroen and Peugeot, now I want to update it with diagbox with this current version, can I install it, or risk of lock ?? thanks in advance friends
    ECU2009
  2. #977
    sergei5005's Avatar
    Nov 2012
    Bs As
    Hi friend. Im have one diagbox Problem. Install ok from V7.02 to V7.60 ..all OK.....But v7.60 to v7.64 is my problem "ERROR DATA ACCES". Someone solved this problem ????? THANKSSSSSSSSSSSSSSSSSSSS
  3. #978
    Jun 2016
    hi, how I can check what version of Lexia I have ?
  4. #979
    BiH
    Interface checker
  5. #980
    Aug 2010
    Hi for all,
    I want update mi firm for Lexia 3 Clone
    What I need?
    Its is my Lexia 3
    Very Thanks!!!
  6. #981
    Jun 2017
    Netherlands
    Please also check the actual SN, it could be banned.
    Just download this zip and unpack into C:\APPLIC\LEXIA\MajAppCom
    https://mega.nz/#!sqQygKjC!SDeSPQ7oe...MD-LFgnDf_8UxA
  7. The Following 2 Users Say Thank You to micheldg For This Useful Post:
    Col19 (25th February, 2019), joe06 (10th February, 2019)
  8. #982
    Jun 2017
    Blackpool
    Default error 0
    Hope you can help me. I am trying to install diagbox V7.01 already patched on my Toshiba Satellite Pro running xp sp3 with netframework 3,5 sp1. every time i try i get activation error 0. i have tried the same software on a friend machine running windows 10 which worked straight away but i need XP to run other programs i have.
    any help would be great.
    Many thanks
    Pete
  9. #983
    Jul 2017
    Disable wifi, enable Lan without a cable connected, keep Bluetooth enabled. I disabled Bluetooth and got the same error, turn it back on and problem solved.
  10. #984
    Nov 2012
    error 0 means no network card detected.
    Reinstall drivers for lan card.
  11. #985
    Nov 2015
    T h a n k s
  12. #986
    I'm looking for update diagbox from 5.20 to 5.29.
  13. #987
    Oct 2018
    Default nice one
    Quote Originally Posted by mattydr67 View Post
    I find it in this forum.
    You can try it
    Thanks to Mr. Scarymistake
    Good luck
    are the drivers also in there?
  14. #988
    May 2017
    argentina
    Could someone send me a firmware for diagbox 7.76, I have the interface with 4.2.9 and better with another newer firmware?
  15. #989
    Nov 2018
    hola amigos, alguien tiene las actualizaciones del diagbox. sobre el 7.76 en adelante. poseo version china, el cual, me ha funcionado bastante bien.
    saludos y gracias por su eterna ayuda.
  16. #990
    Anyone know what the password is for 776 to 782. Scary01 don't work. Maybe lancetech from eBay selling dud stuff. He won't help.. cheers
    Sent from my CLT-L09 using Tapatalk
