Hi Scary ! You can price updates Lexia and address where you can send ? Reply to PM
Scarymistake.
My dear scary, please please help me.
I use windows 7 ultimate system on my pc. I did all the updates perfectly to V7.27. But after upgrading to v7.27 Chinese clone my interface has stopped communicating with the car.
After many attempts I decided to uninstall the software DIAGBOX.
I used Revo uninstaller to uninstall. After that I restarted my pc and installed DIAGBOX V7.02.
So I upgrade to V7.06 and now the software is just asking ACTIVATION. with this sentence:
(you must enable applications to be able to use them at that time, will carry the activation of the equipment).
Scarymistake, please help me.
Or someone here from the DK has been there. already uninstalled and installed over 10 times and nothing.
Hi friends,
I changed my laptop. On my old laptop worked Pp2000 fine (win 7 - xp mode). Now i installed the pp2000 on the newer laptop and when i try work with car i get an error message (wincad error...win87em.dll-0001.02c6...).
I tried to install diagbox 5.02 (on xp mode too), i can install and activate the program fine (5.02) //with 1234..12 and 2fffffff//, but i can't update it, the update program (5.02-5.20) run well, but when i start the diagbox and come the update screen then by end of procedure give fault and then the diagbox already can't run. I tried 5.02-5.03 update, but there is same problem.
I have an clone interface.
Can you help me with any good ideas?
Thanks and HAPPY NEW YEAR!!!
//Sorry for my bad english//
diagbox use could help me with the original interface but does not connect with some cars for example peugeot hoggar any solution?
Hi to all, i have a question, i have diagbox 7.30 installed and work very fine, i want to upgrade to 7.40, is it posible?, there is an update 7.30 to 7.40 of line, or i unistall all, and start new installation from 7.02 patched for to finish with 7,24 to 7,40 ?
Thank to all, an advantage for any answer
Dema2
xilophene (17th April, 2014)
When I install Diagbox 7.40 on my Windows 7, 32 bit I can choose between Diagtool and PP2000. Does Diagtool work for my little bit older car Peugeot 406, 2004? Does it work with PP2000 in Diagbox?
My clone Lexia3 from China can update it? i am worry about locked if update.....
Anyone know why i get activation error (2) on initial install, diagbox 7.1 (chinese shitty clone) using software dvd via Alcohol iso mount, it installs, then always error, (2) to be clear usb lexia inserted or not ? internet on or off ? F**kin tools, never had such a nitemare loading sw, any pointers chaps sure its a schoolboy error on my part,,
Going to try re installing clean, what sw can i use to ensure all files gone, as sure windows folders used on install, cc cleaner ok ??
desperate as car in tomorrow, and need running Diagbox asap,,,
Cheers
have you sorted your activation problem?
If not, do you have .NET framework installed?
No Signature
I have different problem, it installs, activated, sees the interface, and so on. Only after restart when it should become 7.02 it says wstransformer.exe error, installed the updates and so on, butnothing helps.
I try to install on fresh isntall of windows XP SP3 on a virtual machine.
Any help is appreaciated.
Thanks.
No Signature
diagbox work like charme in win7 64 , but you can work just in CAN not k-line
how to enable diagbox thanx
internet on for activate ,but make manuel activation
Carprog 8.21,xprog 5.55,galletto v54,kess and ktag rework
