TM600/500 ToneDeff Blue Panel for UR
Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    Default TM600/500 ToneDeff Blue Panel for UR
    My Version of Blue Panel for TM500/600 UR images.
    The last 2 UR images have an options to add your own Blue Panel Server, started putting this together for myself and it's somehow ended up at this ;P
    Has been Tested/Created only for a TM600 but alot of it should also work on TM500's
    Here's what's on Panel as of 02:30 18/10/10
    - UK Fixed Dish Chan List + EPG cfg
    < Update ChanList / Without Restarting Enigma
    < Get matching channels.uk EPG configs.
    < Auto Update ChanList & EPG cfg Weekly / using crond
    - WeekEPG/Log / WeekEPGLog used by all listed epg plugins to get the data from sat..
    < Install
    < Update EPG data from Sat
    < Set How Many Days Worth of EPG Data to get 1-8.
    < Set WeekEPG location to update /hdd/ or /tmp/
    < Auto Update EPG Data / using crond
    - Multi View EPG
    < Set MV Install location /hdd/ or /mmc/
    < Install
    < Get EPG Data for BBC Radio Stations / downloaded from panel.
    - Update MultiView cfg's
    < Channel Mappings
    < EPG Inputs
    < Update Gui settings
    - EPG.Find / For Searching the EPG data used by MV.
    < Set EPG.Find Install location /hdd/ or /mmc/
    < Install
    < Auto Update EPG Data Twice Weekly or Daily / using crond
    - OpenEPGui
    < Set EPGui Install location /hdd/ or /mmc/
    < Install
    - Auto Start with box options
    < Enable/Disable - Auto-Start
    < View Auto-Start List
    < Enable/Disable - Crond Auto-Start
    < Enable/Disable - ZapStream Auto-Start
    < Make /var/startup/ - Add Own Scripts / Scripts can't have any extensions. e.g "script.sh" wouldn't be run
    - Cron Options / Scripts log into /var/spool/cronlogs/, with full telnet echo and date/time
    < View Cron Jobs.
    < Start/Restart Crond / for when not set in auto start
    < Restart Crond / after changing scripts etc
    < Stop Crond
    < Install & Option to Enable Crontab for Telnet
    - Cron Run Dir's / Add your own scripts to following dir, can't have any extensions. e.g "script.sh" wouldn't be run
    < Every Hour = /var/spool/cron.hourly
    < 4:20 Every Day = /var/spool/cron.daily
    < 5:20 Tuesday/Friday = /var/spool/cron.twiceweekly
    < 5:20 Wednesday = /var/spool/cron.weekly
    - Zapstream Options / for autozapping vlc stream on port 31344
    < Start/Restart ZapStream
    < Stop ZapStream
    < Create StreamTV.m3u for VLC playback / creates /var/StreamTV.m3u for easy opening in VLC.
    - User Scripts
    < Run user Scripts from Panel > /var/script/script1.sh - script5.sh
    - Telnet.. / Add Telnet Commands
    < Add TelZapper / Telnet channel change/search script e.g > telzap disc +1
    < Add 'ChanListUpdate'/ updates to Latest Version of my chanlist without restarting Enigma
    < Add 'wakeup/standby' / Has a Recordigng check on the standby one
    < Add Extra 'busybox' Commands
    /addgroup, adduser, cmp, delgroup, deluser, dirname, egrep, fgrep, ftpget, ftpput, hexdump,
    losetup, md5sum, mesg, renice, strings, stty, tee, traceroute
    - CCcam.cfg Scripts
    < View CCcam.cfg
    < Copy CCcam.cfg for FTP Editing
    < Replace old CCcam.cfg with New .cfg.copy
    < Delete CCcam.cfg
    < Delete CCcam.cfg.copy
    - DVBSnoop Scripts
    < PAT Info
    < CAT Info
    < NIT Info
    < SDT/BAT Info
    < EIT/TOT/TDT Info
    < PMT Info
    - System Info
    < Free RAM
    < Netstat
    < Active connections
    < Current Process's
    < ECM Info
    - VarBackup
    < Install 'VarBackup' Script
    < Backup/Restore /var/ to /hdd/varbackup/varbackup.tar.gz
    < Backup/Restore /var/ to dir /hdd/varbackup/
    < Backup/Restore /var/ to /mmc/varbackup/varbackup.tar.gz
    < Backup/Restore /var/ to dir /mmc/varbackup/
    - Plugin Downloads / that aren't on UR panel
    < PLi WebInterface for UR
    < Preconfigured WeekEPG 3.2b
    < Zapstream
    < Cron..
    < ECM Info
    < DropBear SSH
    < Simple Port Sniffer
    < CCcam Config Switcher
    < Picture in Picture (PiP 0.7b)
    < Mosaic (Transponder Multi Display)
    - Skin Download / that's just for me, still on 4:3..
    - Radio Background Image
    - Scan Background Image
    - Addons Manager
    - ToneDeff
    ftp "myserver.info" in attached zip into /var/etc/
  2. The Following 3 Users Say Thank You to ToneDeff For This Useful Post:
    manxspud (7th April, 2013)
  3. #2
    DK Veteran manxspud's Avatar
    You have been putting a lot of work into this, i just wanted to say thank you.
    @manx
    DK Veteran gibbo74's Avatar
    Nov 2008
    leigh lancs
    great work tonedeff
    does this list include the upto date bbc nw , ive had a lot of people ringing and asking me where has bbc 1 gone .
    satsmo's Avatar
    Jun 2008
    Stuck and thanks for sharing.
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
    Quote Originally Posted by gibbo74 View Post
    great work tonedeff
    The sorted Bouquet uses "BBC London" but the list in full services will be the updated ones for BBC.
    also if they are using TM500/600 UR, install my Panel + Crond + "Update Chan List Weekly" option ;P
    A WebServer you can run on your TM600 has been added to Panel, has full PHP/SQL support, after installing you can then install CCcam.info.PHP to be run on box.
    CCcam.info.PHP 1.2.2 is the version currently on Panel.
    Apr 2009
    Default How
    How do i get to /var/etc folder on tm600
    Any help much appreciated
    Pete
    Nov 2010
    Question reboot tm
    hello people i would like to know how to make a command for my TM to reboot in a daily basis, for example at 5:00 am
    i think that is possible with CRON but i dont know how to do it..
    any help would be apreciated.
    thanks in advance.
    regards
  10. #9
    Nov 2010
    Having a problem accessing the cpanel.xml file at the moment.
    Any ideas?
  11. #10
    Feb 2011
    Does it have the new updated channel list with atlantic
  12. #11
    Feb 2011
    I am just getting into this stuff i downloaded the zip it has an info file how do i use it. I have a tm500 super.
  13. #12
    Feb 2011
    i tried the myserver file by ftp ing it into the var/etc folder.when i run it from the blue buttoni get xml parse error. iam using tm500 super
  14. #13
    Oct 2008
    Ireland
    Quote Originally Posted by Assee View Post
    Try a factory reset that should sort xml parse error.
  15. #14
    Feb 2011
    Thanx mate i got it working Now. Do you have any idea how can i add more channels to the my panel, ans epgui and weekepg.
  16. #15
    Junior Member parricull's Avatar
    Mar 2011
    Lancashire
    does this still get updated regularly with new channel files?
