Page 3 of 8 FirstFirst 12345678 LastLast
Results 31 to 45 of 115
  1. #31
    DK Veteran donkeyboy's Avatar
    Nov 2008
    ~~~~~~~~ me that was a response
    how do i put the picons on if you dont mind me asking
    PS i deleated pick tv coz it didnt work
  2. #32
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    FTP the folder to any off these locations
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory (Sky UK picons will be ok)
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
  3. #33
    Nov 2008
    sorry im still learning
    am i doing this in dreambox edit or DCC
    sorry m8 for the noob question
  4. #34
    DK Veteran reddevil157's Avatar
    Ireland
    Use Dcc to ftp the picons
  5. #35
    Nov 2008
    which file do they go in m8
  6. #36
    Ireland
    I put mine in here: /media/usb
    Recommended if USB available and successfully mounted (8000/800) as recommended by SGTFlipFlop. I've got a 2 gb usb stick that I store them on
  7. #37
    Nov 2008
    ok ive got 2g usb stick so i now put files onto stick is that right
    and then put into back of dm800
  8. #38
    Ireland
    nah m8, put your stick in your box , format it and mount it. Open Dcc, ftp-click media/usb in the left panel, find the unrar'd FlipFlop Picon folder on your pc in the right panel- highlight and press the arrow to the left, takes a bit of time. If I remember correctly.
  9. #39
    Nov 2008
    k man will give it ago
  10. #40
    Scotland
    If the picon directory doesn't exist on the Dreambox send the folder and all the files over, If it is there just send the files
  11. #41
    Apr 2011
    Would anybody be able to figure out where I'm going wrong here?
    I can follow the tutorial, and after rebooting my DM500 I can see the imported bouquets, but If I select any of the channels that show up in the new bouquet, then I just get a blank TV screen. It seems that the information of the imported bouquet doesn't match up with information I have on my box.
    On my box, If I select "User bouquets" and then "Satellites" (green button), I can select Astra, then scroll through to see all the channels that are available, but for instance BBC1 London shows up and works as number 2289, but under the bouqeuts I've loaded on, it shows up as 1 and doesn't work.
    I'm struggling.
    EDIT
    I should point out that I'm on Jade PLi just in case that helps.
    Thanks.
    **EDIT**
    Figured it out myself. From my initial setup, when doing initial transponder scan, I'd been scanning 19.2 and not 28.2. Not sure why it still found channels, but it did. Still, all ok now.
  12. #42
    Oct 2010
    Quote Originally Posted by markshore View Post
    Hi great bouquets but having some trouble with mine i have modified them for use with air video for iphone by adding another bouquet to yours have ticked allow duplicate entries in user bouquets in settings.
    Opened dreambox edit and opened your latest bouquet, opened tools and went to compare loaded services with services from dreambox selected all and updated active file set (showed the changed new frequency for MGM HD as delete?)thought it worked but no it has not any ideas as to where i am going wrong.
    Mark
    Hi anyone any ideas as too where I am going wrong or how this should be done to preserve my modified bouquet, just read in the first post that the Dreambox needs to be re-booted after sending the new bouquets mine always shows the correct info so perhaps that is where I am going wrong with my modified bouquets.
    Mark
  13. #43
    V.I.P. Member barrowmanandrew's Avatar
    scotland
    thanks for the guide, i'm having problems trying to get it work..
    i have followed the instructions, but when i start the ftp i get an error message.
    the box does connect and password etc are correct....
    anybody no where im going wrong?
    i am using commando image if that makes a diffrence
    i finally got it to work
    i used bouquet wizzerd and choose neutrino in firmware setting, ftp working now..
  14. #44
    Jun 2011
    I follow all the guide but when it comes to the part "send files to dreambox i hit it and the following error
    i pull the socked from the dreabox and let it restart wen it does everything is the same, also tried rebooting from the menu but same thin
    where am i goin wrong?
  15. #45
    Jun 2008
    Default db edit bouquet problem
    When I choose the flip flop bouquet there are only two channels there? Its doing something as the fta channels are in the right order if not numbered correctly, and the epg is screwed up too, or do I need a seperate file for that, any ideas?
    Obviously I'm thick, not working at all now, file transfers but remains in alphabetical order on box??
    edit;come in tonight, booted up & hey presto, all correct. All it needs now is a good cline, any suggestions ?
