Scrub that last comment, managed to transfer them ok wrong port number - had 80 instead of 21 doh!
When i scan for channels however i still get none found any ideas?
I have dreambox 600 pvr, i use dreamboxEDIT, I go Tools->Options->Profiles i click Test IP Connection it says Successfully connected...I click Test Username/Password it says Could not connect...(Before that i pressed blue button which is at remote control->Plugins->TuxBox Commander i went to var/etc/ i deleted passwd and i renamed passwd- to passwd and saved it. Normally the username has to be root and password has to be dreambox). I use username: root password: dreambox FTP port: 21 and doesn't work (I mentioned above) i don't know if FTP port: 21 is correct, how can i find the correct FTP port? Why username:root and password:dreambox are wrong? How can i find the correct username and password? Please help me
Hi, I followed the instruction to edit the regional channels by dragging my BBC and ITV regions to the middle window and deleted the Scottish ones, but when I transfer the bouquet they havn't changed. I did save the changes and reboot by the way.
Also the lettering type stays black, not green as the rest of the bouquet list does. Don't know if this is important.
I'm probably missing something simple here so any ideas would be much appreciated.
Billybremner
UPDATE
I've managed to suss this out. I realised That you have to drag your changed channels to the list in the right pane as well, then save your changes and send to VU box.
Last edited by billybremner; 15th October, 2012 at 01:17 PM. Reason: Problem solved
Looking forward to trying this although limited to hotbird access at the moment so not sure what i will get here in Turkey
piopat m8 when i extract this rar file all im getting is a file piopats enigma1 bouquets there dosent seem to be a channel list and when i try to load it in dreambox edit it cant see the file so how do i ftp the file using dreambox edit thanks in advance m8
just downloaded dbedit it says i have to make some changes ie go to set up>system>customize>enable set up mode>export and set multiple bouquets to yes,the problem is i cant find the set up function..any info much appreciated got it they were refering to my box and not dbedit
changed the settings as above but still getting the same message and unable to transfer anything over to the box....anyone any ideas...thanks
Can someone please guide me to the latest sky hd UK bouquet?
DM Bouquets & Skins
Would be a good start
Also thanks for the great guide
Wow, what a great guide. I've been struggling to import bouquets to a dm600 for weeks now. Followed the guide & success !. Many thanks, it will stop me pulling more hair out.
I am currently using Catseye's and Autobouqets.
I first transfer Catseye over to the box, then go to say BBC1 and run autobouquets to generate the 28E lists. This gives me 28E twice, but I don't mind that really. I have then set up pin access for all the not so child friendly bouquets.
At the next release of Catseye, I will then transfer that over, but here's where my questions start. When I have done this in the past, it replaced everything that was there previously and I just ran Autobouquets again.
Does this also mean I will lose the pin locks on the previous bouquets too?
Is there a more efficient way to do what I am doing?
If i decide to update my Bouqets, the new ones overwrite the old ones?
Or i get "kaos" in bouqets
