Page 1 of 5 12345 LastLast
Results 1 to 15 of 73
    spiridonas's Avatar
    Default VAS PC 5054A FLASH CD
    Hi i need flash cd-dvd for update software ecm from audi skoda seat and vw . Please any link - help
    My tool is vas 5054a.
    Many thanks in advance.
    unless anybody knows different, you cannot flash any ECU nowadays using vas-pc, without having an online connection
    maybe earlier versions are capable but for sure with v18 it isnt possible, ive tried using VW flash disc and you have to log on via online connection
    unless im doing ot wrong?
    anybody know a different solution?
    yes you can do if the vas pc show in diagnosis 019 programming
    May 2009
    hi
    can you explain more?
    regards
    Starting VAS PC
    Insert Flash CD
    open Selfdiagnostic, (only in Selfdiagnostic available)
    open ECU
    Soft is automtical checking if newer version on CD
    if it is so, there is an button 019 Programming
    Note: Some Ecu's needs after flashing other procedures like coding or adaption, this must be done manually by user so be careful if you don't know what you do!!
    Remember: You can also copy files from CD to x:\SIDIS\home\datflash then no CD needing.
    Safest way is online
    Quote Originally Posted by morito View Post
    hi
    regards
    DK Veteran Wolfpack's Avatar
    New York U.S.A.
    does the flash disk have files for USA cars or just euro? cause without a Geko id you can't online flash
    Jun 2009
    UK
    Guys, are there any links to VAS flash CD images for Audi, VW, Skoda, Seat?
    difficult to find anything reliable.
    manchester
    Default help needed with vw flash disc please
    have v18 on laptop working great does all functions ,if i want to reflash it downloads info from car then wants to connect to online server which i dont have access to
    so i used update by cd method with head connected to laptop by usb
    select update by cd & all i get is databus fault 200.95 can anyone shed any light on it please
    we are using non original head ,i have tried setting date back on pc to date v18 was released ,we have used unmodified flash dvd ,tried one with a modified label file to expire 2099
    im using vw flash disc v51
    i get no no 19 in self test
    even made dataflash file in c:\SIDIS\home\datflash as it wasnt there & copied all files from datflash on disc into it & still no avail
    trying to check software version on 51 plate polo petrol & update if possible
    any help greatfully received
    martyn
    Hello friends, you can flacher calculators aec vaspc s only if you have line 019
    if the alternative is not VAG COM TECH. Very good for flash
    diagnoza_auto2000's Avatar
    Sibiu
    I want to update a battery ecu on Audi A8 year 2004 ,but i have no update menu 19.
    I use V18 of VAS version and AUDI Flash DVD 05/2010
    Its there a solution to make vas flashing work?
    Jun 2009
    I want flash the gateway in a touran today with FlashDVD, but i have no update menu 19.
    Is this only possible for engine ECU ??
    Can you share the Audi Flash DVD with us
  13. #13
    Sibiu
    Quote Originally Posted by chli1976 View Post
    Its posibile for evry ecu ,but i don t find yet the solution.
    Posting software on Dk its forbiden ,sow i cannot share
  14. #14
    Jun 2009
    One times i have flash a T5 with the Flash DVD and i have there Update 019, but i think it was V17
    I have flash it with DVD after aborted
  15. #15
    Jun 2009
    Now i have flash a Golf VI Diesel 90PS over updateprogramming 019. With the fash DVD
    it`s not working
    I have copy the whole DVD to c:\SIDIS\home\datflash and it works over 019
