Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 117
    RO
    Default Audi A6 from 2006 ELV module (kessy)
    Hi friends, Somebody know if I can repair this module? ELV is dead, car not start, I can make diag only on CAN gateway. I remove the module from car and if I push one switch from pcb, car start. If I put 12V to stering lock motor, works. Lock/unlock stering.
    reference:
    HW: 4F0 905 852B
    3.0
    SW: 4F0 910 852
    01.30
    on PCB I have MC9S12DG128 mask: 3L40K
    Geza
    Romania
    Try to rewrite the ucontroller.be ware it's secured.here is an empty contetnt fron a new brand one but the ucontroller is s12d256.
  3. The Following 22 Users Say Thank You to illestibor For This Useful Post:
    ASCM (7th June, 2020), AVDIMON (29th April, 2016), bmc (6th December, 2019), bokilee (15th January, 2019), br.balazs (8th February, 2015), chefdediag (17th April, 2017), dzevad (24th December, 2020), feketezsolt (6th April, 2017), Geza (19th February, 2016), kojara (17th August, 2013), koki (18th January, 2016), ktome (22nd November, 2020), owdi (12th September, 2021), paulotxr (19th February, 2022), powered by (18th May, 2017), puntt (3rd January, 2018), sazimam11 (16th October, 2019), tomo776 (17th February, 2018), toms4 (7th January, 2016), vanos batam (4th July, 2023), vasa (14th September, 2019), xifly18 (9th December, 2015)
    znoki's Avatar
    Dec 2010
    land of plenty
    Is it a locked processor? Can I read it with Omega?
    If I rewrite the processor, how can I adapt the ELV?
  5. The Following User Says Thank You to znoki For This Useful Post:
    jjas40 (13th September, 2016)
  6. #4
    joubliss's Avatar
    Far away
    Quote Originally Posted by znoki View Post
    K?szi Tibi! ;-)
    Omega dont read secured mcu, try with Rosfar260 or XprogM.
    salerno
    Default info for elv
    hello
    help for 3l60k motorola
    you have read this motorola?
    luigi
  8. #6
    morocco/fbs
    read ok with rosfar r260 tested
  9. #7
    znoki's Avatar
    Dec 2010
    land of plenty
    I've got same problem again, but the processor is 1L59W - MC912DG128.
    4F0905852B, 3.0 , index: 01.60
    Have somebody similar virgin file as illestibor for my processor? (because I need only 2048 byte eeprom file)
    Cheers!
    even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
  10. #8
    morocco/fbs
    yes here is what did you like
    for password chek pm
  11. The Following 11 Users Say Thank You to jokersat For This Useful Post:
    alexjpjp (21st June, 2016), AVDIMON (29th April, 2016), baskom (25th January, 2018), clearly (16th May, 2019), ettaoussi (30th January, 2015), ktome (22nd November, 2020), line44 (28th September, 2017), mariokn (3rd December, 2013), mhz2005 (16th May, 2017), toms4 (7th January, 2016), wokounek (24th March, 2015)
  12. #9
    znoki's Avatar
    Dec 2010
    land of plenty
    Hi Jokersat,
    Thanks for your file, I checked it, but I found a VIN number. Is it virgin?
    What should I do? Reprogram the eeprom area, and than? Online coding? Synchronisation?
    Somebody else said, I should erase and reprogram the flash area. What do you think? Do you have the flash file too?
    Cheers!
  13. The Following User Says Thank You to znoki For This Useful Post:
  14. #10
    Read eeprom+flash by xprogm and put to new (used) elv
    Good luck
  15. #11
    znoki's Avatar
    Dec 2010
    land of plenty
    Quote Originally Posted by milkatrek View Post
    Good luck
    Last time I did similar. I didn't read or write anything, just put the original processor into a new (used) ELV. It is working.
    Now I did the same, but it don't work. So I guess the data is wrong in the eprom or flash.
    Is chinese xprogm working well with locked 9s12?
  16. #12
    sometimes xprogm v5.0 broken elv. Better use oryginal. working 100%
  17. #13
    morocco/fbs
    problem is flash dump
    sometimes if swap ori mcu to second elv can work and somtimes dont work then the problem is flash dump
    tested 100/100
  18. #14
    znoki's Avatar
    Dec 2010
    land of plenty
    Ok, I understand, but I think I can erase only the flash by MTRK and rewrite it. Is it not enough?
  19. The Following User Says Thank You to znoki For This Useful Post:
    slivovica (18th November, 2017)
  20. #15
    morocco/fbs
    pls dont use mtrk omega or orange use xprog m or rosfar to read this mcu
    omega orange dont work with this securised mcu
  21. The Following User Says Thank You to jokersat For This Useful Post:
    clearly (17th May, 2019)
