Page 17 of 24 FirstFirst ... 71213141516171819202122 ... LastLast
Results 241 to 255 of 356
  1. #241
    Feb 2016
    I bought lexia interface, it connecting with 407 2007, but don't communicate with abs block (with other diagnostic abs is communicating)
    And not communite at all with old cars, 206 1999 year, 607 2001 year, with diagbox 7, and pp2000 v25.
    For what reason, for missing optocouplers or something else?
  2. #242
    Feb 2016
    Any help?
    Why can't connect with oldest cars?
    I think for missing 1 optocoupler, 3 from right side?
    Pcb have 1 only.
  3. #243
    Jun 2014
    thanks Anydraj very useful
  4. #244
    titoun's Avatar
    Dec 2010
    Quote Originally Posted by Romcik View Post
    Any help?
    Pcb have 1 only.
    Yes HCPL 063N instead of 2x1kohms (102marking code) and a strange strap.
    But in your place i replace all 0 ohm and transistors by HCPL0500 and HCPL 063N, as in this image:
  5. #245
    Jul 2013
    Hi, I have lexia with low quality board, on the board miss CAN common mode choke filter TDK, there is no place for it. Can I repair this board to work on van and can cars or is better to buy new one. Here is the picture with missing part.
  6. #246
    titoun's Avatar
    Dec 2010
    Quote Originally Posted by Nikola1309 View Post
    The absence of the common mode choke CAN on the relay card will not prevent your interface from functioning, if it does not work it is faulty.
    So either you return it to the seller (Chinese I suppose), or you repair it (or have it repaired).
  7. The Following 2 Users Say Thank You to titoun For This Useful Post:
    Col19 (25th January, 2020), Nikola1309 (31st January, 2017)
  8. #247
    hello my xs evolution is work perfect in can but not communication in van
    what is it please?
    this relay work but not communication
  9. #248
    Oct 2014
    my lexia is not full chip pcb and work well with can car but no work with k-line somebody can help ??? any sugestion thanks in advance
  10. #249
    Mar 2017
    Can anybody help me to solve the problem ?
    I have a full-chip rev. C lexia and works quite ok but does not communicate with hydraulic suspension in Citroen - only :/
    Any suggestions ?
  11. #250
    titoun's Avatar
    Dec 2010
    Hi, check all relays on PCB relay board ....
  12. #251
    Mar 2017
    Well, during car is connected I hear the "click" from the relay when the suspension calculator is trying to be ask
  13. #252
    Apr 2016
    17776764_10211752809951742_1143276172_o.jpg17776764_10211752809951742_1143276172_o.jpg ihave no 5 v in this socket thats why relay pcb dont have 5 v any solution ?
  14. #253
    ubistvo's Avatar
    SERBIA Krusevac
    S O L V E D
    In picture 3 is a fuse witch blow
    I have a problem with lexia
    It wont connect to car
    I tested all but when i looking on dash i found that one component missing
    It should be a capacitor but i not shure 100%
    Did maybe someone know what here go or no???
    P.S
    Can someone tell me what is this on picture 3
    ""Just press THANKS when you think it is useful""
  15. #254
    titoun's Avatar
    Dec 2010
    On picture 3 : Choke 22?H, look my thread here: http://www.digital-kaos.co.uk/forums...to-an-original!
  16. The Following User Says Thank You to titoun For This Useful Post:
  17. #255
    Jun 2017
    Hello
    Lexia, at first did not connect with some calculators, through the whole plate, there is no short circuit, now does not detect her computer, does not light the diode. The voltage on the winbond and on the processor is correct but there are no output voltages at the connector on the second board, maybe someone will suggest what might be damaged or if the led should light as the relay board is not connected.
