Page 20 of 24 FirstFirst ... 1015161718192021222324 LastLast
Results 286 to 300 of 356
  1. #286
    Jan 2017
    Hello.
    I bought a Lexia at this auction:
    https://www.aliexpress.com/item/2016...27424c4dpJ4eqd
    Unfortunately it does not read the VIN and has a communication problem with several car controller. I have Citroen C2 from 2008.
    I undressed the device and noticed that one optocouplers (3 from the left is wrong soldered)
    Should I soldering it by turning 180 degrees like the last one (first right)?
    There is also no resistor 103 (PULL UP) on the other side of the PCB or I should also solder it?
    I'm asking because my board is a bit different than the ones from the topic
    24.08
    I turned the optocoupler and soldered the resistor, unfortunately it did not help. He still does not read the VIN at C2, the Peugeot 1007 read normally. Version 7.57
    Any ideas?
  2. #287
    titoun's Avatar
    Dec 2010
    Quote Originally Posted by 7key View Post
    Hello.
    24.08
    Any ideas?
    HI,
    First , remove four transistors here: (and maybe one of the other side)
    Second, recheck orientation of optocouplers
    B.Regards.
  3. The Following 3 Users Say Thank You to titoun For This Useful Post:
    7key (3rd September, 2018), carpin (10th September, 2018), Col19 (25th January, 2020)
  4. #288
    Jan 2017
    Thank you. I'll do it soon. Which transistor in the back?
    Best regards.
  5. #289
    titoun's Avatar
    Dec 2010
    Best regards.
    Remove two 0 ohm resistor on this side, here :
    and tell me if it's work !
    B.R
  6. The Following User Says Thank You to titoun For This Useful Post:
    Col19 (24th January, 2020)
  7. #290
    Jan 2017
    I desoldered transistors and resistors. XS does not connect with the car (do not hear relay).
    08.09
    I soldered the elements again, "Lexia" connects to my car (Citroen C2 2008) in addition to the "module under the steering wheel" and "air conditioning". It did not merge with C3 2004 with any of the modules.
  8. #291
    titoun's Avatar
    Dec 2010
    Reference of your optocouplers on your VCI ?
    Check if not HCPL 063N and HCPL 0500 , change them !
    http://www.digital-kaos.co.uk/forums...to-an-original!
    B.R
  9. The Following User Says Thank You to titoun For This Useful Post:
    Col19 (31st October, 2019)
  10. #292
    i_shot_the_sheriff's Avatar
    Nov 2008
    I have diagbox 7.44 and suddenly my Lexia has a problem . When i try to open it it says Version.txt is missing or incorrect ....
    Can somebody help with this?
    ( i have a blank version.txt on my c:/ ,,,, also there is a version.txt in APP/LEXIA/EXE and it contains some version info....)
    thanks in advance
  11. #293
    Nov 2008
    Just for the record ,,, i've updated diagbox with a newer version and the problem is fixed
  12. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
    titoun (14th September, 2018)
  13. #294
    Jul 2018
    horncastle,lincs uk
    hi ive a pp2000/lexia,it works fine on peugeots but on citorens says its not plugged into the pc,ive all the drivers etc installed,any ideas?,i had this issue a while ago but cant remember how i fixed it.!
  14. #295
    Jan 2019
    Hello.
    I have a problem with my Lexia interface. After connecting to the computer and installing the drivers, the device is detected correctly once, sometimes with an exclamation mark and sometimes unknown. I do not know what it depends on. After undressing, I had to soldin C49 again because the end was not soldered. It did not help much. I do not know where to look for the fault.
    I have a full chip ver. C chinesee clone.
  15. #296
    Jun 2013
    EU
    Quote Originally Posted by Jedrek View Post
    Hello.
    Do the green led keep lit or it flashes a bit and then remains powered off?
  16. #297
    Mar 2019
    down a hill of chiantishire
    Hi folks, I spent some good time reading this thread since the first MOBILTRONIC post, but i still I am very confused.
    I have a Citroen C3 1.4 16V HDI 2003 with 500K Km on her wheels, still working fine.
    I decied to take care of her by myself, so a couple of year ago I bought a XS EVOLUTION Clone from china.
    I installed Lexia3 on XP and it worked fine.
    Last weekend i decied that i need to add the Diagbox experience, so on a fresh Win7 installation i setted up Diagbox and connected the the XS EVO.
    Something went really wrong since then.
    Both Lexia and DiagBox do not recognize anymore the Actia.
    When connected via USB it powerups, the green led goes on, then it blinks for 3 times.
    Windows XP shows it as Unknow Device with VID_0000 PID_0000 and 5&AD7F4AE&0&1 as sub definition.
    I understand that others had the same problem, but i do not understand if and how they solved it, and last but not the least where they found the tools used in the recovery process.
    What I am really looking for is a tutorial or some hints to start with, could someone be so nice to point me out?
    Any help will be really apreciatedIMG_20190315_063713.jpgIMG_20190315_063729.jpgIMG_20190315_063813.jpgIMG_20190315_063929.jpg
  17. #298
    Jun 2013
    EU
    Default Lexia PP2000 repair
    If the led blinks when you connect to usb but after few blinks it stay powered off i would start changing the ram IC. The f.u.c.k.er in chinese boards tend to die easily and that is the main sympthom.
  18. The Following User Says Thank You to morgano For This Useful Post:
  19. #299
    Mar 2019
    Hi Morgano.
    The led behavior is: once ACTIA is connected to USB port, it power up and stay ON, for 3.5 seconds, then 3 fast blinks within half second, and it ends remaing ON.
    The whole USB recognition process takes from USB connection to UNNKOWN DEV MESSAGE, 12.50 seconds.
    May I ask how is possible that simply connecting the ACTIA to the same pc, but with a different OS, could burn the SAMSUNG RAM?
    Thanks so much!
  20. #300
    Oct 2016
    hi friend i need your help i have clone full chip lexia new , tried it with many cars it works ok with peugeot 406 (2003+) and 307 and newer but tried old cars like 406 2001 didnt recognize vin and not recognize in global test except abs ! what need to be checked pls
