Page 3 of 24 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 356
  1. #31
  2. #32
    didi_du_93000's Avatar
    France Paris
    Lol. You like to program ? RAM? No man just change the RAM and Enjoy.
  3. #33
    Portugal
    I'm having problems with my cable. When I connect to the usb port it is recognized by the pc, the green after flashing is fixed. But when I try to make a diagnosis to any car he says he finds nothing. How can I fix?
  4. #34
    dimitar's Avatar
    Default lexia success
    After jerking around with my lexia conecting only with pc but not with car tested all the above methods but nothing . At first i didnt have 5 volts on pic and relays not working i managed to repair that after same thing relays dont working. Started reprograming all the chips one by one everthing ok with the chips. Finaly tried to reprog 25x80 it turned out to be the problem faulty eprom. Got an old broken laptop with bios eprom 25x80 reprogrammed with the file posted here and voala . Works like charm. Thanks to all participating in this post
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  5. #35
    Quote Originally Posted by Anydraj View Post
    And fuses for Asix Presto...
    tested dump pic16f684!
  6. The Following 8 Users Say Thank You to btr For This Useful Post:
    Col19 (20th June, 2021), Dalautos (10th April, 2019), Elektrik001 (15th April, 2015), frigo (16th August, 2013), johny2h (16th June, 2016), kral06060 (14th July, 2017), nikiver4ov (22nd September, 2020), shtyrya2 (26th September, 2022)
  7. #36
    Quote Originally Posted by btr View Post
    Tested it means work with all cars? Also Peugeot 307 and Citroen c5?
  8. The Following User Says Thank You to nickowski For This Useful Post:
  9. #37
    Quote Originally Posted by nickowski View Post
    Only on peugeot 307 Van.
    My inerface not wont work can-bus cars
  10. #38
    Default not work with can-bus
    Please somebody post pic16f684 dump work 100% with Can-bus cars.!?
    thanks!
  11. #39
    thanks!
    Try these files :
  12. The Following 16 Users Say Thank You to nickowski For This Useful Post:
    AlexDi (15th March, 2023), Col19 (20th June, 2021), Dalautos (10th April, 2019), Elektrik001 (15th April, 2015), frigo (16th August, 2013), hbalazs (22nd March, 2016), hmagga (26th September, 2022), johny2h (16th June, 2016), kral06060 (14th July, 2017), kronk92 (9th November, 2016), mexanico1971 (22nd August, 2014), miltas (21st February, 2018), nikiver4ov (22nd September, 2020), rrr500 (18th July, 2018), titoun (18th February, 2016), varoff (31st January, 2017)
  13. #40
    dimitar's Avatar
    Default Finally solved
    Quote Originally Posted by dimitar View Post
    After conecting to vehicle lexia stopped working. Came home and stared reprograming all the mcus again.Everything ok except the 25x80 eprom which had memory changed. Reprogramed again with the file posted here and tested on the bench, relays started clicking again everthing ok , removed power suply reconected again same thing stopped working , everything okk except relays dont click. Reprogramed the 25x80 again with seeprog, put software write protection and lifted pin 3 and conected with pin 4 and everthing works like charm tested on three vehicles several times still havent tested CAN VAN vehicle thou.
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  14. The Following 2 Users Say Thank You to dimitar For This Useful Post:
    fluorescent (30th June, 2016), mexanico1971 (25th March, 2020)
  15. #41
    dimitar's Avatar
    Try these files :
    Mate check the first page of this thread for the file you were looking for.
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  16. #42
    Try these files :
    Please post fuse bits for pic16f684.Which programmer you read it?
  17. #43
    Aug 2008
    Solved with re soldering of the all components on the boards. Thanks to everyone for help.
  18. #44
    Junior Member Dima_minsk's Avatar
    Republic of BELARUS
    Hi!
    Who can help me to recognize these optocouplers and the big red element (varistor)? I need their catalogue symbols.
    Hello.
    Put please, photos in high resolution the back of the card.
    Thank you.
  19. #45
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Default L&P repair
    Yesterday I had a problem,which is slightly different from other.The interface is not working but was able to run software.So, RAM memory and USB device was correct.Relays did not want to clicking.That two parts I replaced it with one working interface and again everything is ok,without any MCU programming.Best regards.
  20. The Following 2 Users Say Thank You to MOBILTRONIC For This Useful Post:
    johny2h (16th June, 2016), titoun (18th February, 2016)
