Page 13 of 24 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 356
  1. #181
    Junior Member kdijagnostika's Avatar
    Aug 2010
    Osijek, Croatia
    Quote Originally Posted by morfej View Post
    That temic airbag as Zmann said ... work via VAN network... you can't connect directly for shure not.
    br
    Too bad, but why does this Peugeot has a separate K line for the airbag on pin 12? Is not this line directly connected to the airbag ECU?
    Sent from my LG G3 using Tapatalk. KDijagnostika.hr
  2. #182
    So, in the car trace OBD pin12 back to the ECU, if exist you have that possibility.
  3. #183
    morfej's Avatar
    pin12 was used in older cars not C3 I would say.
  4. The Following 4 Users Say Thank You to morfej For This Useful Post:
    Col19 (24th January, 2020), kdijagnostika (7th February, 2016), titoun (16th November, 2015), Zmann (7th November, 2015)
  5. #184
    jolidj's Avatar
    ITALY
    hi. i have version 7.25, sw open , connect to vci all ok.
    but when i serch to finde dtc ore codificatio tool cant finde ecu.
    dont finde nothing, ecu dont fine ,bsi same,abs,airbag ecc ecc all cant finde.
    with other diag i can do diagnostic.
    WHAT IS THE PROBLEM ?
    flash sram, resistor,capacitor , driver??? im confiuse .
    help thanks.
  6. #185
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Lexia reflash went wrong please help. Before reflash was var.B serial I dont remember. appli 4.2.2. After reflash no serial and no version.
  7. #186
    Quote Originally Posted by PSAcars View Post
    Also have seen your another post image.
    -did update with vci_updater? any chance to try second time and see?
    edit, oh no second time for you by this method
    -if no success your internal flash is corrupted you will need to proceed by Fujitsu FlashKit or Fujitsu FMC16LX, search the forum.
  8. The Following 2 Users Say Thank You to Zmann For This Useful Post:
    mexanico1971 (7th November, 2015), titoun (16th November, 2015)
  9. #187
    Dec 2012
    Fund?o - Portugal Cherry Land
    Unhappy
    Good afternoon dear friends,
    I come here to expose my problem, I have a lexia3 interface, chinese I think, and at first it worked well and detetava all modules, but now the time needed to erase a mistake, and diagbox, it is linked to green light this the work but did not recognize the interface for anything.
    I decided to delete the diag and install the PP2000, as for Peugeot 406 hdi comes well.
    After a few attempts he there recognized the interface but does not communicate with the other modules, only detected the engine. And since my colleague had complained that he had also given the same problem.
    What and who will be able to be the problem, can you help me?
    I will leave here some pictures of bugs and interface.
    When it was acquired
    The evidence that has worked with other modules
    The errors
  10. The Following User Says Thank You to Fiesta18d For This Useful Post:
    romyfranco (7th January, 2016)
  11. #188
    Dec 2012
    overs0ull's Avatar
    Nov 2012
    near the sea ... ;)
    i see your tool and is really bad quality bro , but you need to try to fresh install on windows , and after that install separate the lexia and pp2000 and their updates and install all drivrs after that try again it sopouse to work .
    But when i see your tool hardware not sure .....
    Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
    Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
    Info on pm
    Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
  13. #190
    Dec 2012
    For the diagbox, and pp2000, they are installed on different computers machines.
    On what had diagbox even ended up uninstalling diagbox.
    Then I grabbed the other has XP and PP2000, and it managed to diagnose, but only only the engine module.
    Relative to the interface, you say it's a lot of poor quality?
    I mentioned that was Chinese.
  14. #191
    Jan 2016
    Lexia Chines that green LED flashes and stays on. Recognized in the OS (XP) without connecting to the Internet, but not recognized in Lexia or Diagbox.
    Can be any electronic component?
    It has been ressoldado and not solved.
    Regards for instruction to resolve.
  15. #192
    Dufner
    Johnner's Avatar
    Éire
    Hi Oliveira,you're very welcome to Kaos.
    However,you need to introduce yourself first before posting...please do so here : Introduce Yourself
    Thank you...
  16. #193
    meteor80's Avatar
    Hello.
    Maybe someone can help me.
    I have 3 pieces of lexia.
    One is fully working and tworzenie pieces are broken.
    One doesn't recognize that it is connected to car and I have swapped pcb with relays from working one and it looks that problem is on bardzo with mcu? Also relays doesn't click. Sezon one problem is on relay board and it cannot get VIN from car and can't connect to any unit. Swapped boards and the problem is on board with relays.
    Wysłane z mojego F5 przy użyciu Tapatalka
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  17. #194
    Newbie Med01's Avatar
    Dec 2015
    Thanks bro
    Envoy? de mon SM-N9005
  18. #195
    Mar 2014
    thanks to all my friends
