Page 22 of 24 FirstFirst ... 121718192021222324 LastLast
Results 316 to 330 of 356
  1. #316
    Jul 2019
    far far away
    Done some testing and not always Diagbox recognizes VIN - if it dont I need to unplug it from USB and reconnect. Then it works.
    Then used Lexia for my old C2 - sometimes it finds some modules but during global test at some point (random) it shows no connection to module. When I unplug it from USB and plug again it connects to module I chose...but only this one...If I want to change module need to unplug it again and plug back. Could that be related to relays? I noticed that when I plug it in and chose to connect I hear click and it works. But when I change module it doesnt till I unplug it and plug back again. Any ideas guys? Cheers
  2. #317
    Jun 2020
    Hi, my lexia was working fine when i bought it, now after 3 uses it wont comunicate to car.
    Light flashes 3 times and stays on, i can flash firmware to it, drivers working fine but no communication to car. Wont read vin or communicate to any module. I cant hear relays clicking either.
    When connected to 12v relay board has 5v on it.
    Any help on what to check or replace?
  3. #318
    Jun 2014
    I have a strange issue.
    When i plug vci led light comes on for a short time like 1 or 2 seconds then it goes off.
    I have tried to flash it with PSA interface checker, it looks like it stucked on 4.2.4. Its not changing. But when i try to flash it, led comes back on.
    Is it a ram issue ? I guess not...
    And some times version number on it doesnt make any sense at all. Check attachment
    What is my problem ? Any input would be appreciated.
  4. #319
    Sep 2018
    Argentina, Bahia blanca
    Hello everyone, i have an issue, I can't connect with 206+ van protocol, and I can't connect with the ABS either in VAN-CAN or CAN-CAN, the interface wont connect with ABS module of any car
  5. #320
    Oct 2021
    Quote Originally Posted by dvorel View Post
    did you solve the problem with lexia? I have the same problem as you. Thanks !!
  6. #321
    Apr 2021
    Same problem. Computer recognizes the lexia as "evolution" interface, but not read VIN and says "no comunication" in error reading mode. Green LED is on. The interface was working more than year and unexpected stopped. I tryed to change optocouplers, checked the power on the relay board, solder 10k resistor on CAN line but nothing help. It is still dead. Now I am waiting for programmer, which I ordered and will try to reflash processor and memory.
    Edit: I read the flash memory. Can somebody tell me if this dump is correct or not? Seems ok, but...
  7. #322
    Newbie licorne2's Avatar
    May 2013
    algeria
    hi friends I have got a problem with lexia , the cable like vga is shorted so after that I replaced the cable when connect lexia the green light blanks 3 times and stays on , usb not recognized
    I think the small Ic is bad but cant see it label or anything need it pls
  8. #323
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. Liorne2 smd element is USBUF01W6 on my board I have 33omh from pin1 to pin6 and pin3 to pin4.
  9. #324
    Sep 2021
    Hello, My Lexia relays stopped work(click) and interface doesnt react to connect with OBD but recognized full specs of interface in system.
    When i spy my board i saw one missing element, can Anyone tell me what i must solder to red circle point, and this probably can be problem? Regards!
    Please help!
  10. #325
    titoun's Avatar
    Dec 2010
    For your missing component: it's a capacitor, value = ????, but it seems to me that this will not prevent the interface from working.
    Remove AT5 on microprocessor PCB, and in absolute you should to replace all optocouplers by originals. see my post here : https://www.digital-kaos.co.uk/forum...to-an-original!
    B.Regards
  11. #326
    Sep 2021
    I`ve found info about missing capacitor, and his value are 125nF i solder 100nF because only that i have, but this nothing change.
    I also check all connections like at this site https://www.drive2.ru/l/466145377372865144/ and all seems okay.
    Resolder almost all pins and points.
    "Remove AT5 on microprocessor PCB," What element exactly you mean?
    About replacing elements to near original of course i do that, but first i need to repair connection to car:/
  12. The Following User Says Thank You to Zwyczajny For This Useful Post:
    titoun (24th April, 2022)
  13. #327
    Sep 2021
    Okay, i swap between U4 and U5 octocouplers to test and relays Alive!, So i must replace with original all of the octocouplers.
    Hope to work fuuly
  14. The Following User Says Thank You to Zwyczajny For This Useful Post:
  15. #328
    Sep 2021
    Quote Originally Posted by titoun View Post
    B.Regards
    Do You think i can use 0631 Octocoupler instead 063N?
    I've got two genuine pieces, and i think it will be a way better than fake 0369.
    I tjink to solder them in U7 and U8 pionts.
  16. The Following User Says Thank You to Zwyczajny For This Useful Post:
  17. #329
    Sep 2021
    Attachment 882714
    My 0631octocouplers
  18. The Following User Says Thank You to Zwyczajny For This Useful Post:
  19. #330
    Sep 2021
    Okay, sorry for my spam, but i replace U7 and U8 with 0631 and lexia are faster now. Calculators are readed in milisecons, not two-three like before . So i'm going with next upgrades.
  20. The Following User Says Thank You to Zwyczajny For This Useful Post:
