hello my problem is that the lexia connects only to the engine ECU and the air bag but does not connect with the bsi and the other ECU is new I have only used 3 times I could be the driver ULN2003 ayudra
hello my problem is that the lexia connects only to the engine ECU and the air bag but does not connect with the bsi and the other ECU is new I have only used 3 times I could be the driver ULN2003 could help me
Can anybody tell me where to buy a good clone because i bought one in amazon and it was damage and according to tho photos that were posted mine is a bad clone
thanks nikolasky
flashing winbond 25W80 eeprom !!!
Diagbox ver. 6.09 works fine Peugeot 508 model, but does not work Peugeot 307 1.6 hdi 90hp wagon 2007 model. Tried and PPS Diagbox programs and they both asked as soon as identification number of the car.
My Lexia can not connect to car ECUs, green LED is always ON. Soft is DiagBox v.6.01. What I should check first?
Have same problem man. After program update dead. No communication with car at all.
Have you flashed the vci?
Most interfaces work with diagbox up to 5.29. From 5.30 the vci need to be reflashed. Ask scarymistake.
titoun (18th February, 2016)
Who has experience with reflashing Lexia with PSA Checher utility?
I flashed it with psa but pp always flash to required version when starts, I will try to instal DB 5.29 today and I will report...
Look on The Girls forum .. You will find what you need...Oh! you cant ..its ****in closed ..
can we change winbond 25W80 eeprom with 25080?
