Page 2 of 24 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 357
  1. #16
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Default Lexia PP200 repair
    Quote Originally Posted by gixxer View Post
    This "new" RAM must flash or only change?
    Thank you!
    Only change,RAM,mate.Regards.
  2. The Following User Says Thank You to MOBILTRONIC For This Useful Post:
    FeerLaas (21st June, 2019)
  3. #17
    Jul 2010
    Hi!
    Who can help me to recognize these optocouplers and the big red element (varistor)? I need their catalogue symbols.
  4. #18
    Nov 2010
    Original interface RAM BSI
    Clone interface RAM Samsung
  5. #19
    Jul 2010
    Quote Originally Posted by nickowski View Post
    Hi!
    Optocouplers: HCPL-0500 & HCPL-063N.
  6. #20
    Jul 2009
    Found the RAM problem too...
    USe same size and access speed. Vendor is not important.
    Why program RAM? pls read any tech datasheet for its function, then ask questions.
  7. #21
    Senior Member gixxer's Avatar
    Mar 2009
    Europe
    Quote Originally Posted by MOBILTRONIC View Post
    Hi,mates.For fixed interface must change it RAM memory
    Hello
    I changed RAM, and interface work!!!
    Million thank You!!
  8. #22
    Aug 2009
    someone can post picture ram location in interface
  9. #23
    Mar 2009
    Europe
    #10 ...................
  10. #24
    Jan 2010
    Default ram changed, but not work...
    I have exactly the same problem as a member Anydraj someone ... you have any ideas please?
    thank very much...
  11. #25
    Aug 2009
    Hello
    Million thank You!!
    hi where i can buy this ram
  12. #26
    Mar 2009
    Europe
    Quote Originally Posted by motorsport View Post
    I bought from Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.
    Ram type BSI SRAM 4M 256kx16
    Product search ---> "BS616LV4017EIP55"
    (if You French: http://fr.farnell.com)
  13. The Following 2 Users Say Thank You to gixxer For This Useful Post:
    Col19 (24th January, 2020), titoun (18th February, 2016)
  14. #27
    Apr 2010
    GB
    Hey guys...
    I have a problem with Actia PP2000, I can not connect with pc,
    usb PC cann't communicate with Actia.. Unknown device..
    What is the problem
    Many thanks guys
  15. #28
    Aug 2008
    My interface after connecting to pc the green light turns on then off after 2-3 sec. If I start lexia or pp2000 the pc restart's with bsod massage bad_pool_header. What can be the problem.
  16. #29
    Apr 2010
    GB
    Quote Originally Posted by backo View Post
    I Think interface is normally, maybe from software PP2000,
    My Interface green light is always On...
  17. #30
    Mar 2009
    Europe
    Hello
    Me too this was, and MOBILTRONIC user suggest that change SRAM I changed, and now work!
    (Read #10, #26 post)
