Audi Allroad 2,5d PSG5, 132 KW. 2001 year, Code motora AKE
I have a problem when I give gas and the rpm drops and reaches 1200 rpm, then the rpm does not go down to base gas, but stops and the engine starts shaking at this rpm. There is no error code in the engine controller and the parameters are also good. The engine starts normally and runs normally at other revs. I replaced the flow control valve. The pre-ignition controller works fine. When I do the test with VCDS, the engine works fine and it also changes the ignition angle. Has anyone seen this problem before?
