Results 1 to 14 of 14
    Jun 2010
    Default Leibherr green key, terex BCS service codes!
    hi all,
    love the site, bit of a newbie, but want to show my appriciation somehow, if anyone wants terex bcs service codes or how to make leibher service keys or Hitachi winDR let me know and i will see if i can help,
    cheers
    Jun 2010
    3k ohm = green
    10k ohm = red
    press thanks!
    Jun 2010
    just realised the pin configuration could help,
    its across pins 4 and 9, of a RS232 DB9 plug. the same as a laptop serial port,
    cheers
    Newbie fai-dirly's Avatar
    Dec 2009
    Quote Originally Posted by king189 View Post
    cheers
    hai friends....
    software connect to liebherr????
    Member alfoin's Avatar
    Nov 2009
    the two keys are put in the same resistance pin
    May 2010
    Australia
    3k ohm = green
    10k ohm = red
    press thanks!
    is this for liebherr machines?
    Can you please post a schematic for the Liebherr key?
    Thanks!!!!
    Jun 2010
    buy a seriel/db9 plug, from your local electronics store and solder either a 3k ohm for a green key or a 10k ohm for a red key from pin 4 to pin 9 then plug it into the digger just above the right armrest, cheers
    May 2010
    Australia
    i cant remember if this is a male or female db9 plug?
    Jun 2010
    male pins, digger side is female,
  11. #11
    May 2010
    Australia
    yeh all good there are 2 female ports and one male port on the ESP01 card, just wasnt sure which one the key was suppost to go in, i aquired a genuine green key and made a red key. Have you seen LTS software available anywhere?
  12. #12
    Feb 2017
    Help with the scheme
  13. #13
    Feb 2017
    Does not work soldered to 4 and 9 pin
  14. #14
    Sep 2022
    So you can just put a 10k resistor in 4 & 9 pin?
