Results 1 to 4 of 4
    V.I.P. Member Dreamer's Avatar
    Apr 2008
    Glasgow area
    Default bella italia spag cabonara
    to serve
    * 1 tsp olive oil
    * Freshly ground black pepper
    Method
    1. Fill a large pan with boiling water
    2. Add the spaghetti and cook as per the manufacturers instruction
    3. Heat a non stick pan with a touch of oil
    4. Cut the pancetta or the bacon into small cubes and sautee until crispy
    5. In a large bowl, beat the egg yolks and the parmesan until you get a creamy sauce
    6. Drain the pasta one minute before you should, and add to the pan with the bacon, off the heat
    7. Next add the egg mix and toss together or mix well. The egg mix will lightly cover the pasta and may scramble slightly (this is normal)
    8. Serve, and top with a generous amount of ground pepper
    NB. The egg mix will cook from the heat of the pasta while the dish is being served.
    Cli
    The Falkirk Wheel. The only rotating boat lift of its kind in the world
    xant14's Avatar
    Mental Mowbray
    Heers dreamer... will give this a go tomorrow... or maybe next day... got loads of road kill in at the min, picked a rabbi up today, and the deer other day..
    Good menu up tho... and nearly always have the stuff in fridge.
    Aug 2011
    I guess it would be even better if you added a little garlic sauteed with the pacetta.
    Oh and of course a bottle of wine to go along with the spaghetti.
    Sep 2011
    nice! thanks
