Could use some help with a flash file for esn 06R0894449 version 2.28 please and thanks in advance
Hello All, does any one know how i can find out what the correct cal/flash file is for a 14 Litre ddec V Ecm. The Unit or engine number is #06R0810259. Also need to know if anyone can share the file/files with me. Would you know if the calibration with Detroit Cal tool is similar to doing it with Insite?
where can i get a step by step process of calibrating the ecm.
Thanks in Advance
Please share DDEC V 14L 06R0795382 calibration file for DRS.
Thanks in advance........
Does this program not need kg?
Hello, please help with calibration for ESN 06R0456685, thanks!!!
I am looking for a Calibration / Flash File for a Detroit 60 Series Engine
Engine Serial 06R0361623
Thanks!
HI
hi
can someone re upload the drs 6 part 2 file or any other version of detroit reprogramming system that dont require a key
i think the link is damaged
Hi guys.
I need help with series 60 calibration on the
06R0340511 SK60 engine.
i need the DDRS Software Calibration_Files for these DDEC V engine serial numbers: 06R0874463 & 06R0906083, Horsepower: 550.
Any response/help would be appreciated.
i also need Detroit DRS Calibration files for 60_Series DDEC V Engines; S/N 06R0874463 & 06R0906083
I"m also need a DRS cal for S60 DDEC 4 S/N 06R0436046 thank you
In search of Cal Files for serial number 06R0563317. This would save ton of time to be able to change original for new application. Thank You
Thanks Jabkissmya,
i wanted to find out if there are few things you can help me with kind of new to the DRS software. basically i am in africa and have 60 series ddec 4 and 5 engines 12.7 non egr. how do i reprogram the ecm once i have swapped it from an accident truck to another truck where the ecm is condemned.
Thanks your post
Что именно вы хотите сделать ?
