Please somebody can help me with the calibration.
If it is just a bk 500 hp,you can look through the cals posted on this thread and find one that will work.I have some cals I have saved but nothing for that exact ser #.I mix and match a lot.Just check your ser and part #s for same camshaft,injectors,ect. and it should work.Might have to to change your input/outputs to match.
I have a truck look
but I can not move because this parameter with the ECM password
I remove the password
ANYONE KNOW HOW TO REMOVE THE PASSWORD
THANKS FOR THE HELP
hello all thanks for all the useful info but i have ddrs6.46/7.0x on my comp can i also install drs 6.14 thanks in advance
can some one post part1 and part2 of the drs download as im getting an error says that it cannot be read from the server maybe the link is down thanx a million
help me with the following "calibrations" please
06R0172921
06R0606673
06R0473017
Jabkissmya!
Help me with cal file
06R0888676
Thanks in advance!
mepodrian ayudar con unas calibraciones para motores estacionarios de ditroid diesel estos son los # de motor 06RE116997 06RE116872 GRASIAS
Good night, and I have the program installed and calibration files of Detroit, the problem is not how to use it, my request is to increase engine horsepower Freightliener and Kenworth trucks.
I need to know which file to use seeing horsepower, rpm, torque, etc.
Be held in Cummins and Caterpillar perfect, thank you help me to do well in Detroit.
Thanks,
The problem with detroit is the serial numbers dont tell what they are like a cat or cummins.You can convert each one to dct and it will tell you this but it is a slow process.With dct you can change anything you want just use moderation until you learn what you are doing.I only use drs to burn blank ecm.Then I use dct to change what I want.
Good afternoon,
jabkissmya: Friend, I need your help to locate the file 06R0830535.
ddmech: Friend, I have the dct program and understand that it must change the rating. Do you have any manual or suggestion to change the horsepower.
Thank you very much,
just a thought,but i just found this in another thread...but come to think of it,i think this will only effect the temp correction,which will not change the overall settings...maybe we need to look further for the main setting tables and do something similar with those...worth a try i think...
Tip for the day. To increase fuel, open calibration, go to:
SHARED, TABLES, temperature compensation, torque_temp_correction
Left click top corner of the 1D table so the whole table turns black. Right click, select block offset and add whatever percentage you want to increase horsepower by. I.E 0.1 = 10% horsepower and torque increase.
Whoo Hoo, there'll be some blown apart green motors now!!!!
The ir is no manual or info on the dct except for the help file that I know of.The best source of info is to read and reread the dct thread here on DK.More info on here than anywhere else that I am aware of.As far as increasinf power with dct it is more of a trial and error thing.Just go slow and make minor changes until you lear what you are doing.Also you can take another cal from a higher horsepower motor and download it.If you choose this route make 100% sure that they have same cam,injectors,ect.,or you wont get the performance you want.Hope this helps.
