Please share calibration for 06R0178237 Model 6067WK60.
Hi m8.
have tried the link by Jabkismya but still failed to get the required result thats why I had decided to post my request in this thread.For some reason all the downloads I have manged to download have failed to work and those on the Rapidshare Links I have FAILED to download.
regards
Donniemnemonic
Question for Series 60 experts. Where there any 14 liter non EGR engines with the compact valve train?
Thanks,
Emgo
Hi guys
Need cal file for ddec 5 engine number 06R785374.
THANKS IN ADVNCE.
DDEC Reprogramming System.rar requested cals for this week
bnolann (26th September, 2013), Emgo (25th September, 2013), harobaua (15th March, 2015), helboy1985 (26th September, 2014), jackalfa (25th September, 2013), Juanincho (30th September, 2013), kotok008 (4th September, 2018), leva (22nd August, 2023), makura (24th September, 2013), mang5087 (25th September, 2013), otoy (10th September, 2016), Poptest (25th September, 2013), rmgm81 (20th January, 2019), snapon2 (9th December, 2013), SpbPirat (13th October, 2013), tklove04 (29th October, 2013), trucks (7th November, 2013), vicente456 (30th March, 2024)
hello i have a question, anyone can create a calibration file?
and how to do. thanks in advance friends.
You can do it using DRS.
Sent from my GT-I9500
Share and use the THANKS button and from time to time somebody will help.
PD. Use the REPUTATION button too.
if you have cal tool installed it installs a program under detroit diesel called create calibration that you can do exactly that with.
Please jabkissmya, can you help me with this cal? 06R0304238 6067GK28, if possible soft version 9 and 32; thanks in advance...
One question: this calibration is for a bus with an allison auto trans B500, did somebody know the proper setting in DRS Transmission type in FEI & Trans tab?
thanks again,
hello Poptest this is what i understand from main code and boot code...
main code is when the ecm is calibrated, and boot code is when the ecm no have calibration...
Poptest (14th October, 2013)
Not exactly, Main code is the ECM ready to run the engine, You vector to the Boot code to read and write calibrations. dddl makes the switch automatically when you transmit a setting change, where ddc you have to do it manually. Also if you are in boot code and key off, the ecm starts up in run mode (main code) and can only be put into boot mode in the first 60 seconds I believe.
peter21 (1st October, 2013)
