HII
helpme please, i need calibration 06R0689112
pls helpme and thank for the help
HII
Help me i need cal engine 04HR001192
Please, someone can share a cal from a 06R0417888Engine model:6067GK62 Engine SeriesSeries 60 (No EGR) version 8, , is OK too, thanks in advance.
470 HP thanks
Hi m8
M looking for drs calibration files for ddec 5 ecms with software levels of 2.0 and 1.0 all i have downloaded sofar are for software level 3.01. Have a DDEC 5 ecm in boot mode that i would like to recalibrate.
Donniemnemonic
there is a calibration similar to your engine 06R0616721
Could someone get me a met file Version 2.01 for DDEC V? Or the calibration file for 06R0804681?
Here yo go friend, the .met file you need, however you should have it in C:\Detroit Diesel\Calibration Tool\Metafiles\ddec 5_met5
amosquedat (1st September, 2020), leva (22nd August, 2023), otoy (10th September, 2016), r59slayer (24th January, 2018), Underpsi (28th November, 2014)
Hi guys
I am looking for a cal file for serial number 06R0122808 ddec 3 to calibrate using ddrs
Hello, I wonder if you can change calibration of an engine:
6063mk32-- 400hp @ 2100 rpm, change it to
325hp @ 2100 rpm --1150lb-ft @ 1200rpm
You sure can, if that is the lowest stock setting, you can manually edit the cal in dct... though it's usually to go bigger not smaller.
You could give me the calibration for editing and tell me what software I use.
