Page 5 of 41 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 602
  1. #61
    makura's Avatar
    Got it going at last,had to disable aux out put H2 and the accelarator came to life.
  2. #62
    Quote Originally Posted by makura View Post
  3. #63
    makura's Avatar
    Quote Originally Posted by jabkissmya View Post
    Thanks for all the help mate
  4. #64
    your welcome
  5. #65
    Top Poster Juanincho's Avatar
    Aug 2010
    OK makura you're welcome (P.S. on't rely on esn only, sometimes the engine has been changed from another truck (specially if changed to or from an inter cab to freigh or peterbilt cab) , so the best way to have it working is to check the truck directly, I mean, check the truck if everything works after a cal, )
    Last edited by Juanincho; 8th December, 2010 at 02:38 AM. Reason: Better explaination
  6. #66
    Quote Originally Posted by Juanincho View Post
    True and as well, most cals are put on server before engine ever gets put in truck, so parameters usually aren't 100 percent correct. Most dealers are suppose to update to server so that it gets corrected, but it doesn't happen.
  7. #67
    makura's Avatar
    Ok guys,point noted,but i always use the number engraved on the engine block its self,any way i am not that good with ddecs but i am slowly getting there,i am a cummins guy.
  8. #68
    well we are not saying not to use the serial number for engine, just that you always have to recheck and assume parameters might not be correct.
  9. #69
    Aug 2010
    I agree m8 ... simply sometimes using the actual esn doesnt mean you wont have any trouble. Greetings.
  10. #70
    Top Poster peter21's Avatar
    San Miguel, SV
    hi buddy i need you help again...... i need calibration for serial number 06R0340244.
    Thanks in advanced....
  11. #71
    Hello
    I need to icall 06R0758932
  12. #72
    Could I have cal for 06R0961955 please?
    Thanks in advance
  13. #73
    Last 3 requests added, sorry for long wait, had family buisness to tend to.
  14. The Following 5 Users Say Thank You to jabkissmya For This Useful Post:
    je69 (3rd June, 2015), kotok008 (9th January, 2017), mang5087 (24th September, 2013), otoy (6th September, 2016), vasyaha (30th August, 2016)
  15. #74
    San Miguel, SV
    thank you buddy.......
  16. #75
    Nov 2010
    Hey guys,
    not sure if im doing something wrong here I have DRS 6.16 and when I try to open It says I need a password. See attached
