Page 6 of 41 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 602
  1. #76
    Quote Originally Posted by Underpsi View Post
    Hey guys,
    not sure if im doing something wrong here I have DRS 6.16 and when I try to open It says I need a password. See attached
    Check post 12!
  2. #77
    Nov 2010
    I didn't realize that was for the same problem.
    Now I have another issue though. That message is now gone but when I click on it to open it the Detroit window that always pops up when they are loading, pops up but for less than 2 seconds and then it just goes away and never loads
  3. #78
    That happened to me when installing DDRS / DDRS on a laptop with Windows 7. It works fine on my other laptop with Windows XP. It may not work on Windows 7.
  4. #79
    Nov 2010
    Quote Originally Posted by Emgo View Post
    The laptop im using is Windows XP with windows sp2 as ive heard of people having problems with sp3.
  5. #80
    reinstall drs, then use only the crack in post 12, do not modify drssec.dll.
  6. #81
    Dec 2010
    Hi m8s, I need cal for engine 06R0757368, 6067MV6E
    Thanks !
  7. #82
    Nov 2010
    Quote Originally Posted by jabkissmya View Post
    Tried that couple times, copied the file for DRS6 and its still doing the same. Tried restarting and same thing yet.
  8. #83
    makura's Avatar
    you have to copy it toC:/programfiles/detroit diesel/detroit reprogramming. not just c:/detroit reprogramming.
  9. #84
    Nov 2010
    Quote Originally Posted by makura View Post
    Ya thats what I did, still no luck.
  10. #85
    Default drs problem
    hello , look like you haveing problem with you drs
    how can I help you with ???
  11. #86
    are you ther??
  12. #87
    Nov 2010
    Quote Originally Posted by ECM specialist View Post
    As long as your not trying to sell me something. If you look back a few posts in the thread you will see the issues im having with opening DRS.
  13. #88
    Top Poster peter21's Avatar
    San Miguel, SV
    hi buddy, try unninstalling DRS, then clean the registry with the program CCleaner, restart the pc and reinstall DRS
  14. #89
    Nov 2010
    Quote Originally Posted by peter21 View Post
    Whats a program cleaner that would be good to use? I've never used one before. Maybe something from trying the old crack file is still there...
  15. #90
    Dec 2010
    After clean the registry with CCleaner ( u can search on google), restart ur pc and download other DRS setup file. Then reinstall. Maybe DRS setup file on ur pc erro - try again with another.
