Page 1 of 41 12345611 ... LastLast
Results 1 to 15 of 602
    Top Poster Juanincho's Avatar
    Aug 2010
    Wink DRS 6 and DDEC V files
    Anybody have files (calibrations) for DDEC V to install in DRS 6 ? Thanks for sharing !
    Quote Originally Posted by Juanincho View Post
    engine serials?
    Aug 2010
    Default Engine serial numbers
    06R0810415
    06R0795570
    06R0807355
    06R0734321
    06R0812379
    06R0858298
    06R0858345
    06R0790377
    06R0799568
    06R0833576
    06R0800025
    you may need to upgrade to a newer version of drs depending on which one you have, so i have included drs 6.16
    just extract folder to c:\detroit diesel and copy/merge/overwright files as needed.
    when you run drs it will tell you it is being upgraded and shut back down, this is just giving you the new server updates to install new ecm versions. Click program, if truck does not have a matching serial to whats on you list, it will let you select from a list what you want to program and you should see all serials you listed plus 06R1999999. this is the turbo actuator program for use with dddl 6.44 and higher. save all accumulated data before programming. as it might loose all accumulated data during reprogram.
  5. The Following 42 Users Say Thank You to jabkissmya For This Useful Post:
    12V92TAB (18th January, 2019), 4hillbilly (15th February, 2014), AdrianCR (2nd November, 2023), AMBSOLUTIONS (9th May, 2020), amosquedat (1st September, 2020), autotec2 (7th August, 2016), bullseyemods (17th April, 2013), deez (30th January, 2015), Diseal tech (15th July, 2013), djz4248 (2nd September, 2013), DK007 (9th April, 2014), donniemnemonic (25th June, 2013), dredo07 (11th February, 2022), Edrenan1 (20th June, 2013), Elfer (22nd November, 2013), harobaua (8th March, 2014), hieu1987 (20th September, 2013), hrobertdm (17th September, 2013), hugos31 (14th April, 2013), Israel07 (22nd August, 2014), jakec94 (2nd April, 2019), juan79 (29th April, 2014), koper (16th December, 2023), kotok008 (1st June, 2021), kwagga (4th May, 2013), leva (6th August, 2023), mang5087 (10th June, 2013), matt75 (8th October, 2020), melgarejo.salomon (23rd July, 2015), mmfix (16th February, 2024), northplains (24th February, 2014), oldwest1971 (29th October, 2023), otoy (20th July, 2016), Poptest (16th September, 2013), RobSher2016 (9th September, 2017), Thatguy1999 (17th April, 2015), TjGill (7th February, 2023), topitopi (7th April, 2014), toshor (4th August, 2013), truckinspector (19th January, 2014)
    Member Texas149's Avatar
    USA
    Default Help!!!
    I got it going thanks
    Aug 2010
    Quote Originally Posted by Texas149 View Post
    I need the program file for a seies 60, engine serial# 06R0324268 ecm soft verson 32.08, 430 hp I was going in to change ecm inputs for cruise and accidentally hit update calibration at DDC instead and now ecm is in boot mode! Please help!
    Just to be sure, it is a 6067GK60 engine? Download some other serial number then use dct to change sengine serial number, max rpm and so on.
    Last edited by Juanincho; 18th November, 2010 at 05:27 PM. Reason: better explaination
    so i take it all worked correctly?
    USA
    how do we import cal files into drs?
  10. #9
    Aug 2010
    Default OOps !
    I can't get drs 6.16 work on win 7, I'll try on winxp.
  11. #10
    copy folder as i specified in post, drs will pick it up when you go to program an ecm.
  12. The Following User Says Thank You to jabkissmya For This Useful Post:
  13. #11
    been working on wondows 7 for me, not designed for it, so may have to run in compatibilty mode for some versions.
  14. The Following User Says Thank You to jabkissmya For This Useful Post:
  15. #12
    for those of you using the drssec.dll fix, do not use that, that is an old parallel crack and does not work with this version. go to a topic that states ddrs help, i have posted a link to sentinelkeyw.dll, copy and replace. that is a usb engineer crack.
    her is thread : http://www.digital-kaos.co.uk/forums...50/index3.html
  16. The Following User Says Thank You to jabkissmya For This Useful Post:
  17. #13
    USA
    working on xp for me
  18. #14
    Aug 2010
    Default Thanks !
    Thank you very much ! Everything is fine now Working in both winxp and win7. Great job !
  19. #15
    Top Poster peter21's Avatar
    San Miguel, SV
    Default thanksss
    thank you sooo much buddy, working fine on xp sp3....
  20. The Following User Says Thank You to peter21 For This Useful Post:
