Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Dec 2009
    Quote Originally Posted by ernesto1670 View Post
    Something is going on with this.
    Herewith the result of reading. (With the VDO pin up)
    Can not read the MCU. I believe that the calve is the need to lift the pin.
    Xtal: 4MHz
    Maybe UPA is unable to work with this MCU.
    Ernesto
    Your photo looks seriously bad. Unless the programmer is verified that it's not broken, Im not sure that we can do anything else. One thing you can do is running HW test 'Tools>Hardware test>self test' and see.
  2. #17
    Jul 2010
    Spain
    After several attempts, I decided not to waste more time.
    Buy the ETL, and in 5 minutes had the eprom read and programmed.
    I recommend it to everyone.
    Thank you all for your advice.
    Greetings
  3. #18
    puiu's Avatar
    Timisoara
    Greetings
    Yes ETL is the best solution,
    sory i see just now you post,
    you can read it with UPA,
    but only desoldered from PCB
    solder a 4 MHz quarz
    and all wires like in UPA manual and is working
    or can make an adapter,
    in circuit i try and is not working...
    maybe this help others ,
    Puiu
  4. #19
    alclot's Avatar
    Sep 2009
    Melee Island
    Hello. I also am having trouble reading this mic with the UPA. If you can read well, what pins should be lifted? I've tried without raising any pin and does not read well. The UPA is original.
    Greetings and thank you.
  5. #20
    Mar 2016
    Greetings
    Original ETL or chinatown?
  6. #21
    May 2011
    hi
    connect only 4 wire , tx,rx,5volt and gnd no need to connect any other wires
    read write all ok if the mcu is not secured
