Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
  1. #31
    Talking
    "amigos primero que nada muchas gracias por los link realmente e tenido muchos problemas con los camiones mack como por ejemplo,granite,vicion,pinacles.
    alojor estoy haciendo algo mal con el softwares VMACK III lo necesito con urgencia serian tan amables en poder ayudarme con este problema que tengo nota instale tambien el ssoftwares VCADS pero entro en algunos modelos por ejemplo los vicion pero solamente pude mirar ni siquiera programar les envio una foto del error que me hace el softwares pleace heeeeeeeeeeeeelp "
    Sorry we cant understand what your saying. You must have the same problem as macromantis. The first thing you must do is scan your PC for a virus. If that doesnt fix the scrambled text problem you will then need to replace your keyboard. Once you get that problem fixed please visit the rules section and we will be happy to help you with any problems afterwards.
  2. #32
    Jun 2011
    Default Install first the interface and later the vmack program
    Quote Originally Posted by rp1210a View Post
    "amigos buenas noche tengo un problema con el software de mack lll , si alguien me puede ayudar se los agraderia mucho . instale el programa y los driver de nexiq pero en preferencias no me reconose los driver de nexiq y no puedo conectarme . "
    macromantis, I think the problem is your keyboard. The text is all scrambled. Replace it and let us know if that fixes your problem. Also check the rules section. There may be a few tips there on getting your adapter to work.
    Install first the interface and later the vmack III program
  3. #33
    Top Poster SaMirakle's Avatar
    Jan 2011
    Does anyone know if this version (2.9.4) can connect to a V-Mac II or is it only for V-Mac III's?
    Thanks!!!!
    ---:..Gratitude is the best attitude..:---
  4. #34
    DK Veteran mathura's Avatar
    Aug 2011
    Quote Originally Posted by SaMirakle View Post
    Thanks!!!!
    I had probelms connecting to V-Mac 11 with this version, not sure what the probelm was but I resorted to use of the flash codes to solve the probelm. I will also like to know the answer to this.
  5. #35
    Jan 2011
    Hmm. Yeah I found an older version in another forum on here that I think works with V-mac II and III but the download links are dead unfortunately
  6. #36
    Top Poster Juanincho's Avatar
    Aug 2010
    Quote Originally Posted by mathura View Post
    Yes, sure, vmacss will work for both vmac2 and vmac3.
  7. #37
    Top Poster cbp's Avatar
    Default nexiq usb link fix needed
    hello mates.
    can someone please repost the fix for Nexiq USB link for VMAC III 2.9.4 version?
    cheers.
    My wife said that i have no hair, have big ears ..but a great smile.
  8. #38
    Default nexiq usb link fix for vmac II and III
    hello mates...
    I found the communication problem solution for the nexiq usb link for MACK VII and VIII.
    please ty it out and let me know if worked ok...I tried it and worked fine.
    link bellow
    http://rapidshare.com/files/62841468....2_drivers.rar
    cheers..
    hey dont forget the thanks button.....
  9. The Following 3 Users Say Thank You to cbp For This Useful Post:
    lsinc1 (20th April, 2013), oscar0627 (25th March, 2013), whalla (23rd February, 2014)
  10. #39
    Sep 2011
    Usa
    hello could you reupload files
  11. #40
    Sep 2011
    Usa
    Quote Originally Posted by diesel-tech View Post
    FOR ANY BODY THAT NEEDS IT AND HAS USE FOR IT, THIS IS FOR VMACK III DEALER RPOGRAMMING ONLY LATEST FILES http://rapidshare.com/files/44020727...stallation.zip
    could you reupload
  12. #41
    Aug 2011
    Please Can someone share the program that works with V-MacII
  13. #42
    the only mack pc based sw that works for vmack II is techtool or old version of vcads or there is one more sw that mack use to use wich is a dos program i can upload if any one needs it i can also upload dos software for v mack 1 if anyone needs
  14. #43
    Sep 2011
    Usa
    Upload vmac1 I need it also need reference and calibration files
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  15. #44
  16. The Following 4 Users Say Thank You to diesel-tech For This Useful Post:
    mathura (4th March, 2014), ramsi17 (4th March, 2014), tap50 (3rd March, 2014), whalla (3rd March, 2014)
  17. #45
    Sep 2011
    Usa
    Thanks man
