Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    workshop
    bad dump,how read?on obd dont read immodata
  2. #17
    Oct 2017
    OK, it is a bad dump?
    I am using Kess
    V2 V5.017. According to documentation, we can read AM29 chip OK. Yes, I know needs SD for clone, but renew using OBD should be possible, no? It uses K-Line through OBD?
    I can desolder and read with Willem for comparison.
  3. #18
    Oct 2017
    use vvdi mb tool for renew this ecu
  4. #19
    Oct 2017
    Thank you for the responses. I desoldered the chip and used the Willem programmer, and the binary looks better. It has more data in it than the Kess OBDII read, so maybe Kess doesn't work either.
    Anyhow, I am attaching the original binary, and the renew file from MB Renew. Can someone check if the original or the renew file are correct?
    Thnx!
    Original_Read_11_willem.rar
    Original_Read_11_willem.bin_renew.rar
  5. #20
    Oct 2017
    OK, so I downloaded and compared the original vs renew files posted from peppery and it seems like the trick is to write 0xF from 0x4000 to 0x7fff? I have seen also that MB Renew also tries to write 0xF in that region, but it only writes certain bytes, doesn’t blank the whole region.
    I have seen other renew files from other boards, and they also selectively blank out certain bytes but not the whole region, and with all of the renews from MB Renew, they never work. Well they do, but they get a "START ERROR" afterwards.
    So am I safe to just blank out the entire region as mr. peppery does? I know, I can just try it, but its a pain in the a$$ to keep soldering and de-soldering. Especially because you can't remove the aluminium heat spreader, and it wont let you air blow the chip easily.
    Help! THNX!
  6. #21
    Have you soluce for immo off this ecu?
    With emulator is possible?
    Thx
  7. #22
    Oct 2017
    Well, I'm still trying, If I figure this out, Ill let you know.
    So I'm going with the trick I mentioned above, but cannot write to the AM29F400BB chip! Willem keeps giving me an error. There shouldn't be any special trick, so they suggest maybe the flash is a write-once special version? So now the chip is a ROM, and there is no more re-writing? But I don't see anyone else complaining so now I'm stuck. Do I buy a new chip, which should be R/W? Does this make any sense? I checked the region according to Willem it is not locked....
  8. #23
    avital's Avatar
    vagimmocalculator.com
    Quote Originally Posted by CIRCUIT.FR View Post
    Thx
    Yes with emulator is possible.
  9. #24
    please what emulator can do it?
    thx
  10. #25
    Gavra's Avatar
    Belgrade/Melbourne
    Quote Originally Posted by MBCluster View Post
    Help! THNX!
    That ECU is renewed without opening and coded to car easy.......get better tools for MB
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  11. #26
    Nov 2015
    this tools secret ?
  12. #27
    Bllinda's Avatar
    Baltic
    today
    A topic that interests me
  13. #28
    Nov 2015
    Anyone can help me for synchronization EIS & ME ?
    Vito 10.2006
    ME2.8 (112 153 81 79 _ 0 261 201 165) EEprom 95P08
    EIS: 639 545 05 08 ( with two mcu 1L02M )
  14. #29
    Bllinda's Avatar
    Baltic
    Try .... Next you need a star
    today
  15. The Following User Says Thank You to Bllinda For This Useful Post:
    Frankcar (13th February, 2018)
