    Dec 2010
    Default VCDS Status: Failed Self Test!?????
    using a cable bought from ebay.
    can anyone help?
    cipijoint's Avatar
    the problem for this i s the ATF16v8B inside vagcom.
    you need a new one and program with a jed file to work properly.
    Most happens to damage this ic because of not stable usb port . . either you was charging your laptop while diagnosis, or laptop shutdown when running diagnosis.
    What kind of laptop have you used?
    dont talk a lot and nothing
    Dec 2010
    A new chip??
    I wasn't charging the laptop at the time. And i havent got to the part where i can run diagnostics yet!
    It's an acer netbook
    cipijoint's Avatar
    you can try though to reprogramm the atmega 162, sometimes the content go corrupt .
    but most of time its the atf16v8b fault in this case.
    Dec 2010
    To reprogram the chip will i need to solder to the cable?
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by PaulHam View Post
    For the ATMEGA you can program it via ISP
    For the GAL you need to dessold it from the circuit and them reflash.
    Did it help? Push Thanks below
