Notes before we start: whenever you stir this, make sure you scrape off anything that's stuck to the bottom of the pan. (Probably the kidney beans if you use cheap ones like I do.)
Put enough olive oil in the pan to entirely cover the base, and turn the heat up to 5. Rinse the kidney beans, add to the oil, and stir. Chop two onions into thin strips and dice the other two, add to the pan, and stir. Cut the chilli peppers in half lengthways, then chop them into little strips crosswise. Peel the garlic and crush it into the pan. Grind some black pepper into the pan, stir it all together, and let it cook for a few minutes until the onions are translucent. (You may like to add a little water to stop the onions and beans sticking to the pan.)
Add all the remaining ingredients (plus some extra water so that every thing's covered) and stir well, then turn the heat up to 6 and cook, stirring occasionally, until the chilli is bubbling. Now turn the heat down to 3, put the lid on the pan (to stop any more water from evaporating), and cook for at least another 40 minutes; the longer the better, really. Lift the lid and stir every 20 minutes or so.
Serve with long-grain rice and grated mature Cheddar cheese.
Enjoy
Mubz
Growing old is inevitable, growing up is optional ...
