Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Hybrid View
    chakahafed's Avatar
    Dec 2009
    nouakchott
    Default Mercedes W164 ISM DAMAGED
    HI
    I have a mb W164 WITH A DAMAGED ism (intelligent servo module)
    and the car can't start becose the gear box not inisialized
    i swapped with a nother one but no way
    what i have to do ?
    if i get a new one from the dealer should i have to programe it using csn coding on line ?
    pleas help
    Nov 2009
    workshop
    yes,after 5 minut can you start car
    scn online.mb-dealer or you have star with licens
    and sd online
    Dec 2009
    ISM module has no SCN coding. You need only StarDiagnosis,
    simply do initial startup.
    Nov 2009
    workshop
    yes,only automatic gear ecu
    chakahafed's Avatar
    Dec 2009
    nouakchott
    thanks for answer
    do you think its possible to use a user ism
    or i have to get a new one from dealer
    thnx
    Nov 2009
    Use a new one would be better.
    world wide
    i have the same problem and also i have one used ISM. can i put this on my car and make it working?
    I have Xentry 11/2010. Can somebody explain to me the procedure?
    Oct 2022
    use Das go to ism ,,,,,control unit adapatations,initial startup and follow promts....only if u fitting a virgined unit
    Sep 2009
    Aug 2010
    Should I unzip your ISM, and soldering them rebuild. You need to lose weight gearbox and let it down. ISM's is fixed in three screws. After you get you have to remove all the silicone you will find the shape and Torx screws. You have also screw in the center.
    After you've opened, you may find a cold solder joint to the connector or to find a little engine brushes blocked (80% of cases)
    Regards
  11. The Following User Says Thank You to Bazil_mb For This Useful Post:
    PeterOBD (6th March, 2020)
  12. #11
    Mar 2011
    Dear Brazil_mb,
    I have read that you have post in this forum information about ISM modul. I have one not working ISM with following fault codes: 1994, 1904 and 1974.
    I have open it but can not see visible problem. Could you please tell me how can I fix this problems.
    Thank you in advance!
    Best Regards
  13. #12
    Mar 2011
    Quote Originally Posted by Bazil_mb View Post
    Regards
    Dear Brazil_mb,
    Best Regards
  14. #13
    chakahafed's Avatar
    Dec 2009
    nouakchott
    I HAVE ALREADY DONE WITH 6 ISM IN 164
    A ONLINE ACTIVATION IS NESSECERY FOR A NEW ONE
  15. #14
    amrif's Avatar
    Dec 2009
    EU
    You can reflash ST10F269
  16. #15
    chakahafed's Avatar
    Dec 2009
    nouakchott
    Quote Originally Posted by amrif View Post
    HOW TO ??????
