Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    chakahafed's Avatar
    nouakchott
    Default Mercedes W164 ISM DAMAGED
    HI
    I have a mb W164 WITH A DAMAGED ism (intelligent servo module)
    and the car can't start becose the gear box not inisialized
    i swapped with a nother one but no way
    what i have to do ?
    if i get a new one from the dealer should i have to programe it using csn coding on line ?
    pleas help
    workshop
    yes,after 5 minut can you start car
    scn online.mb-dealer or you have star with licens
    and sd online
    ISM module has no SCN coding. You need only StarDiagnosis,
    simply do initial startup.
    workshop
    yes,only automatic gear ecu
    chakahafed's Avatar
    nouakchott
    thanks for answer
    do you think its possible to use a user ism
    or i have to get a new one from dealer
    thnx
    Use a new one would be better.
    world wide
    i have the same problem and also i have one used ISM. can i put this on my car and make it working?
    I have Xentry 11/2010. Can somebody explain to me the procedure?
    Aug 2010
    Should I unzip your ISM, and soldering them rebuild. You need to lose weight gearbox and let it down. ISM's is fixed in three screws. After you get you have to remove all the silicone you will find the shape and Torx screws. You have also screw in the center.
    After you've opened, you may find a cold solder joint to the connector or to find a little engine brushes blocked (80% of cases)
  10. The Following User Says Thank You to Bazil_mb For This Useful Post:
    PeterOBD (6th March, 2020)
  11. #10
    chakahafed's Avatar
    nouakchott
    I HAVE ALREADY DONE WITH 6 ISM IN 164
    A ONLINE ACTIVATION IS NESSECERY FOR A NEW ONE
  12. #11
    amrif's Avatar
    EU
    You can reflash ST10F269
  13. #12
    chakahafed's Avatar
    nouakchott
    Quote Originally Posted by amrif View Post
    HOW TO ??????
  14. #13
    amrif's Avatar
    EU
  15. #14
    GameTheoryOptimal's Avatar
    Jun 2016
    Canada
    sorry to bring an old post from the dust, but I would have an ISM to fix or replace on a W164...
    the last link about fixing flash is a 404 error, file not found...
    can someone explain me what type of fix could be made in flash?
    I just don't want to invest the 1850$ it would cost me to update my AVDI so I can virgin the donor, and if I transfer flash from original ISM to donor's one, I'm afraid I won't fix the problem.
    so any help is more than welcome guys!!!!
    thanks!
  16. #15
    workshop
    renew donor with avdi,learning to car with star,no need scn
