Page 75 of 75 FirstFirst ... 2565707172737475
Results 1,111 to 1,124 of 1124
  1. #1111
    Mar 2013
    south africa
    hi people, please kindly help with activation key DDL6,45 pc is DMYLZ2PL
  2. #1112
    Aug 2011
    USA
    Quote Originally Posted by bronwynbarnard View Post
    1074164872
  3. #1113
    Mar 2013
    south africa
    Hi guys I'm looking for activation code for dhl 6.4 pc id DMFYH6B0
  4. #1114
    Mar 2013
    south africa
    Thanks very much
  5. #1115
    Mar 2013
    south africa
    Thanks Cnckulp. I have reloaded on another hard drive that's why I am looking for another activation code
  6. #1116
    Nov 2012
    TRY
    enjoy
    23408122
  7. #1117
    Aug 2018
    Anyone have the branding file that gives product level 4?
  8. #1118
    Mar 2013
    south africa
    Thank you very much Morton 03
  9. #1119
    Message deleted
  10. #1120
    Apr 2016
    Hi can anyone help with the following. thanks in advance much appreciated
    tool id DMVB7Y40
    computer id 8C-CF-7D-4B-70
    DDEC
    KIND REGARDS
  11. #1121
    Mar 2018
    Can someone please help with the following?
    Version 08.03-03069-00000
    Computer ID D1-10-1C-46-71
    thanks in advance
  12. #1122
    Mar 2019
    hello Im new
    A3-6B-FE-61-B0 Id
    07.05SP2-01301-00017 version
  13. #1123
    Feb 2020
    Ga.USA
    if anyone can help half of it works just cant get it to open everything
    not sure how to ask im having trouble getting my whole detroit program back up and running because my computer crashed i down remember how to set it up but this is what I have
    DDDL 6.46 & 7.06
    Component Version Application Components
    Detroit Diesel Diagnostic Link 07.05SP2-01301-00017
    S-API 01.02SP1b-00377-00004
    Caesar 03.01.20 (Nov 20 2009 16:13:00)
    System Information
    Operating System Microsoft Windows NT 6.1.7601 Service Pack 1
    .NET Framework 2.0.50727.8806
    Computer ID BC-42-AC-31-7D
    Access Levels
    Read Level 15
    Write Level 15
    Hardware Level 4
    Dependent Files
    Log File
    Trace File C:\Detroit Diesel\Drumroll\Technical Support\Trace Files\2-23-2020 1917.16.DrumrollTrace
    Summary File
    Package Information
    Panels 2.0
    Compatibility Table 519
    Supported Devices
    ACM02T 2.81.65
    CPC02T 1.10.13
    CPC2 1.20.11
    J1587ECU 2.15.0
    J1939ECU 1.19.3
    MCM 2.84.14
    MCM02T 4.40.42
    VECU_UDS 0.0.2
    Configured Translators
    NEXIQ USB Link
    Instrument Panels
    Trip Data 9
    All Instruments 6
    Chart 3
    Data Stream (EPA10) 7
    Cruise Control (EPA10) 14
    Cruise Control 11
    EGR - DD15 (EPA10) (DD13,DD15,DD16) 23
    EGR - DD15 (DD13,DD15) 19
    EGR (MBE4000,MBE900,S60) 16
    Engine Brake - DD15 (EPA10) (DD13,DD15,DD16) 21
    Engine Brake - DD15 (DD13,DD15) 19
    Engine Brake (MBE4000,MBE900,S60) 16
    Fuel System - DD15 (DD13,DD15) 12
    Mechanical - DD15 (EPA10) (DD13,DD15,DD16) 18
    Mechanical - DD15 (DD13,DD15) 16
    Mechanical (MBE4000,MBE900,S60) 13
    Switches (EPA10) 12
    Switches 8
    User 3
    Service Routine Panels
    All Services 3
    ATD Maximum Sensor Value Reset (DD13,DD15,DD16,MBE4000,MBE900,S60) 22
    ATD Test Pipe 31
    Check VIN Synchronization 61
    DEF Coolant Valve Control (DD13,DD15,DD16) 61
    DEF Quantity Test (EPA10) 62
    DPF Ash Accumulation (EPA10) 94
    DPF Ash Accumulation 91
    EGR DP Sensor Recalibration (EPA10) (DD13,DD15,DD16) 18
    EGR DP Sensor Recalibration (DD13,DD15,S60) 16
    Engine Idle Shutdown 64
    HC Doser (EPA10) 47
    HC Doser 49
    Injector Codes (EPA10) (DD13,DD15,DD16) 71
    Injector Codes (DD13,DD15,MBE4000,MBE900,S60) 64
    Leak Detection (DD13,DD15) 48
    PLV Change (EPA10) (DD13,DD15,DD16) 16
    PLV Change (DD13,DD15) 13
    Rating (EPA10) 24
    Rating 23
    Real-time Clock (EPA10) 13
    Real-time Clock 12
    Relative Compression Test (EPA10) 9
    Relative Compression Test 8
    Replace Quantity Control Valve (EPA10) (DD13,DD15,DD16) 16
    Replace Quantity Control Valve (DD13,DD15) 12
    SCR Air Pressure System Check (EPA10) (DD13,DD15,DD16) 21
    SCR Replacement (EPA10) 72
    Total Fuel Quantity Check (DD13,DD15,DD16) 32
    Turbo Actuator (S60) 21
    Activate Outputs (EPA10) 18
    Activate Outputs 9
    Air Mass Adaptation (MBE4000,MBE900) 31
    DPF System (EPA10) 87
    DPF System 66
    FIS Fuel Quantity Control Valve (DD13,DD15,DD16) 244
    FIS Leak Detection (DD13,DD15,DD16) 112
    FIS System Pressures (DD13,DD15,DD16) 75
    Idle Speed Balance (EPA10) (DD13,DD15,DD16) 69
    Idle Speed Balance (DD13,DD15,MBE4000,MBE900,S60) 42
    Intake Throttle Valve (EPA10) 5
    Intake Throttle Valve 4
    SCR System (EPA10) 86
    Voltages - MBE4000 (MBE4000) 18
    Voltages - MBE900 (MBE900) 17
    Voltages - S60 (S60) 16
    Voltages (EPA10) 11
    Voltages SCR DPF 32
    Voltages (DD13,DD15) 17
    Cylinder Cutout Test (Automatic) (S60) 89
    Cylinder Cutout Test (Manual) (EPA10) 10
    Cylinder Cutout Test (Manual) 9
    Parameter Panels
    All Parameters 16
    Compare Parameters 184
    Cruise Control (EPA10) 17
    Cruise Control 14
    Engine Brake Config - DD15-S60 (DD15,S60) 20
    Engine Brake Config - MBE (MBE4000,MBE900) 21
    Engine Brake Config (EPA10) 15
    Engine Protection (EPA10) 19
    Engine Protection 15
    Fan (EPA10) 2
    Fan 2
    Fleet Management (EPA10) 2
    Fleet Management 1
    Idle and PTO Shutdown (EPA10) 15
    Idle and PTO Shutdown 12
    Inputs and Outputs (EPA10) 22
    Inputs and Outputs 23
    Optimized Idle (EPA10) 11
    Optimized Idle 7
    Progressive Shift (EPA10) 18
    Progressive Shift 13
    PTO (EPA10) 12
    PTO 11
    Speed Limiter (EPA10) 13
    Speed Limiter 12
    Update Information
    Last Server Connection 7/28/2010 9:04:38 AM Eastern Daylight Time
  14. #1124
    Jan 2020
    HARARE ,ZIMBABWE
    Quote Originally Posted by hawkeye6969 View Post
    DDDL 6.46 & 7.06
    System Information
    Access Levels
    Read Level 15
    Write Level 15
    Hardware Level 4
    Dependent Files
    Log File
    Summary File
    Package Information
    Panels 2.0
    Supported Devices
    ACM02T 2.81.65
    CPC02T 1.10.13
    CPC2 1.20.11
    J1587ECU 2.15.0
    J1939ECU 1.19.3
    MCM 2.84.14
    MCM02T 4.40.42
    VECU_UDS 0.0.2
    NEXIQ USB Link
    Instrument Panels
    Trip Data 9
    All Instruments 6
    Chart 3
    Cruise Control 11
    Switches (EPA10) 12
    Switches 8
    User 3
    All Services 3
    ATD Test Pipe 31
    HC Doser (EPA10) 47
    HC Doser 49
    Rating (EPA10) 24
    Rating 23
    Real-time Clock 12
    Activate Outputs 9
    DPF System 66
    Voltages (EPA10) 11
    Voltages SCR DPF 32
    Parameter Panels
    All Parameters 16
    Cruise Control 14
    Fan (EPA10) 2
    Fan 2
    Fleet Management 1
    Optimized Idle 7
    PTO (EPA10) 12
    PTO 11
    Speed Limiter 12
    Update Information
    can anyone provide me with a registration key ,my computer ID B0-9E-B9-0D DDDL VERSION 8.11
