Page 3 of 20 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 294
  1. #31
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by browno View Post
    I had originally softmodded my wii and by accident updated to 4.2 e, Itr says in the instructions if you have home brew installed follow these instructions??...i did have homebrew but that disapered when i updated.
    Which instructions do i follow.....
    Same thing happened to my mate when his kid put Fifa 11 in and updated to 4.3.From what i know the new update removes the Homebrew Channel but i was told if the Wii was modded before like yours you can use a copied version of Indianna Jones Lego Original Adventures and then use the 4.3 hack files to mod it again. If it aint been modded then you need the original game.
    if i was you download a copy and burn a disk and give it a go,for educational purposes of course.
    4.3 Guide below if you aint got it,i found i didnt have to play whole level just starting it worked for me.
    http://www.digital-kaos.co.uk/forums...-3-mod-157379/
    Andy
  2. #32
    Jan 2011
    Default hi all
    Im about to attempt to hack my Wii 4.3e. Im just getting everything ready and i need to post so i can download the hack files.
    Thanks for the easy to follow instructions, lets see if im capable.hehe..As for getting through the first stage of indiana jones, ill leave that to my son
  3. #33
    Thanks for all the replies that have been helpful so far.
    Just a few more questions.
    Which is best Wii Backup Manager or WBFS Manager?
    Is USB Loader GX the best or is there a better one?
    And finally I've bought 320GB WD hardrive. Do I have to format the whole disk as WBFS or can I partition it into 2 so that I can put other backup files on one partition and Wii games on the other partition.
    Any advice greatly appreciated
    Thanks again
  4. #34
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by northerngeezer View Post
    Thanks again
    yes you can have a dual partition try this Digital Kaos - Downloads - Partition wizzard home
    if you format to wbfs then use wbfs manager.
    if you format to fat32 then use wii backup manager.
    now for loaders no loader is really better than another just down to preference.
    there is an advantage of running fat32 like if you have any problems your pc can read it and you can defrag it much easier.
  5. #35
    Oct 2010
    How long does it take to download the base wad files to sd card mine is stuck on file 31 of 34 been like it for 20 minutes ive clicked on unfrreze.bat but its still the same.
  6. #36
    nottingham
    Quote Originally Posted by malteser View Post
    should not take that long, cancel and try again
  7. #37
    Jan 2011
    Default iNSTALLED C.O.D bLACK oPS
    I HAVE USED AN ORIGINAL cod GAME THAT HAS NOW OVERRIDDEN EVERYTHING I HAD ON MY WII, HOW G=CAN I STOP GAMES FROM PUTTING A SOFTWARE UPDATE ON WII
  8. #38
    nottingham
    Quote Originally Posted by Growler75 View Post
    install priiloader http://code.google.com/p/priiloader/
  9. #39
    Jan 2011
    I just bought a Wasabi chip, I will try the tutorial with a copy o indiana jones, it should work??
    I just don?t want to spend money on DVD?s
    cheers
  10. #40
    Apr 2009
    no need for indy now modmii have the solution
  11. #41
    nottingham
    Quote Originally Posted by tobnvodka View Post
    yes you do still need one of the exploits.
  12. #42
    Jan 2011
    I tried the indy mod as per the original post. Everything seemed to go as per instrucions. I made a backup dvd of Wii Party. When I inserted the DVD it appeared fine in the disk channel. I clicked on it and the first screen appeared. However when I clicked 'Start' the following error message appeared:
    "An error had occurred. Please eject the game disk and press the power button to restart your wii".
    I tried a different game as well and got the same error. Normal games work fine.
    Any help much appreciated.
  13. #43
    nottingham
    Quote Originally Posted by dingledaly View Post
    is it a new wii?
  14. #44
    Jan 2011
    Quote Originally Posted by ck-ok View Post
    is it a new wii?
    It was bought in Feb 2010. It originally had an os lower than 4.3, but I had upgraded to 4.3 by mistake
  15. #45
    nottingham
    are you using the normal disc channel or neogamma channel?
    what dvd-rs did you use?
    and what program did you use to burn it with?
