Page 3 of 23 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 331
  1. #31
    PierreTheron's Avatar
    Centurion,South Africa
    As you cansee from above posts contact member addick on this. hewill give you instructions how to proceed ...
  2. The Following User Says Thank You to PierreTheron For This Useful Post:
    slavisac (18th May, 2016)
  3. #32
    Minsk, Belarus
    You have 2 used key (1,2), I generation one used (2) and one new (3), but what is problemm have your car?
    May be Immo have errors: "defective modul"
    BR
  4. The Following 2 Users Say Thank You to adikk For This Useful Post:
    PierreTheron (19th July, 2017), slavisac (19th May, 2016)
  5. #33
    GB
    NO errors in immo.Owner wanted spare key.Thank you adikk.
  6. #34
    Wirral
    anyone know if we can write a remote into these? had a few with alarm and it will not turn off without, even tho the engine is running. I am replacing immo with matching remote key and virginising ECU at the moment, but must be a better way on lost keys???
  7. The Following User Says Thank You to parapilot For This Useful Post:
    MarkPRP (9th June, 2016)
  8. #35
    HI
    w168 key has been lost
    Can I have the transponder data from 1d69j dump Please
  9. #36
    find attached keys
  10. #37
    Sep 2015
    Earth
    hello friends
    i need to generate new key with looking
    i read immobox with orange 5 here the dump.
    how can i write the key
    thanks a lot
    bmw for ever
  11. #38
    Done a W168 A140 lost keys today, read ID69J with Orange5, added a new key to #02 position3 with Abrites Tagkey.
    Car started and switched off after around 30sec, now I have Start Error on clock
    Anyone know a solution as to how to cure this problem?
    Thanks in advance.
  12. #39
    Sep 2015
    Earth
    any pcf you used ? your batterie is ok ?
    bmw for ever
  13. #40
    Quote Originally Posted by Masterprog View Post
    PCF7935 and battery fully charged with BSU attached
  14. #41
    Jun 2015
    do you make key with original avdi or with clon fvdi because fvdi don't make good key for a class w168
  15. #42
    Jun 2015
    make shuur the instalation of cables is good + and - courant and immobilizer antenna is good
  16. #43
    Apr 2012
    Hi colleagues! i need some help with generate key for W168 please if someone can help me with this! Many thanks!
  17. #44
    Minsk, Belarus
    You have 3 used key, I generation 3 (used) and 7 (not used) key. Write PCF nd config its as write in .txt BR
  18. The Following 2 Users Say Thank You to adikk For This Useful Post:
    doctore (13th November, 2016), iuliannj (12th November, 2016)
  19. #45
    Minsk, Belarus
    try its, but i dont work with your programmer. Pass same
  20. The Following User Says Thank You to adikk For This Useful Post:
