Try repair damp of IMMO and post resalt
still not working
Hello.,
i need the transponder data for this dump (w168 1d69j)
regards
hi,
I have the same problem, lost key same immo, 1998 slk230 (r170)
I have avdi das2 (failed to read eeprom, no luck working in their special functions. I removed chip read with ak500, loaded file to avdi, no luck or Im out of luck, cannot write sections thats what AVdi says.
loaded bin file and the key dump that doesnt work
kindly check and produce working one. thanks!
olo_3 (5th April, 2018)
I have similar problem, used genuine Tango to add key merc w168 5WK4736 but its still Start Error. Here immobox dump
hi need to generate 2 keys for it .its A-class dump is below . i try abritus but worked only 1 time.
After write chip of Abritus car start only 1 times?
mbail (26th May, 2018), PierreTheron (26th May, 2018)
has it run1 time and after start error. i write second chip the same . the chips are unlock not recognise id. can you send me keys and how to lock?
Member adikk will do keys on these 100%
Follow his instructions
Tools you need might be EFFI pcf7935 and then tango or old HITAG 2 reader
here is abrites key via tmpro2 read
recognize PCF7935
ID44 - JMA TP14
data : 0F BD 77 00 00 00 00 00 00 00 00 00 00 00 81 01
You have 5 used key in damp!!! (1-5), your upload key #7 (data : 0F BD 77 00 00 00 00 00 00 00 00 00 00 00 81 01). Try write any my damp (if You dont use its or wrote to back original damp of 1d69j) and manual configure chip as in .txt
mbail (30th May, 2018)
thanks adikk . i load the processor file again .write 2 keys with abritus and all ok.
Please friend's I have the mercedes A class W168 whith all key lost I have read the Hc05 1d69j How can I create a transponder x to start the car?
many thank's
p.s. I have the zed bull clone and abitrus FVDI 2015 for programming pcf7935
