Detroit Diesel S60 - Spray Tips - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Sep 2010
    Quote Originally Posted by amishmafia00 View Post
    any idea what difference the spray angle makes?
    In this paper, the spray development and its interaction with the piston geometry were investigated in a small-bore high-speed direct-injection optical diesel engine. The effects of injection angle, injection timing, injection pressure, and injection fuel quantity were studied. The entire liquid spray cycle was visualized by a background-corrected Mie-scattering technique using a high-speed digital video camera synchronized with a high-repetition-rate copper vapour laser. For some conditions, the initial injection velocity was estimated quantitatively. The results show that the injection angle and injection timing predominantly control the spray interaction with the piston geometry and the resulting air?fuel mixing mode. Narrow-angle injection leads to a significantly different air?fuel mixing process from the traditional wide-angle injector. If properly controlled, the narrow-angle direct-injection technique offers more flexibility on injection timing control with the fuel confined in the central bowl region without wetting the cylinder liner
  2. #17
    May 2010
    Has anybody come across N-3 injector nozzles for sale?
  3. #18
    Sep 2010
    We had a set extrude honed. the guys said they looked just like 5.9 cummins commonrail injector tips there are factory injectors that have higher flow than a truck injector
  4. #19
    May 2010
    That would be nice if the could be crossed to a cummins injector!!
  5. #20
    Sep 2010
    yeah it would. I didn't look into it any farther. but i know the common rail injectors have aftermarket stuff available. and even some from bosch i think. When we took our injectors apart there was a number on the nozzle. if i remember right it was a bosch number. that would give you a good place to start trying to cross it
  6. #21
    Sep 2010
  7. #22
    DK Veteran Poptest's Avatar
    Sep 2010
    Default Series 60 DDEC 3 N2 Injectors
    Hello DK,
    I just pulled down all N2 injectors with different part numbers from a Series 60 DDEC 3 engine.
    Can some DK brother share how to determine the correct injector part number for a specific engine model or serial number?
    Many thanks in advance.....
  8. #23
    Sep 2010
    Post deleted
  9. #24
    May 2010
    Whats the engine serial #
  10. #25
    Sep 2010
    Thanks,
    I will post esn tomorrow.
    Is there a book or software which will show the correct injector for a specific engine serial number?
  11. #26
    Sep 2010
    Please share what this N2 injector fault means:
    "Injector response time too long"
    Thank you
  12. #27
    Sep 2010
    Quote Originally Posted by rebel127 View Post
    Engine serial #: 06R0340375
    Model: 6067GK60
  13. #28
    May 2010
    Should have R5235575 INJ"S in there.
  14. #29
    Mar 2010
    Costa Rica
    hi guys i need a flash file for detroit 4 06R0255094 help me with this cal please
