Results 1 to 14 of 14
    V.I.P. Member barrowmanandrew's Avatar
    scotland
    Default short guide on gamecarts
    before you post for help with your gamecart, please have a read here and make sure that you include all relevent information.
    THE GAMECART:
    there are many diffrent types of gamecarts available today.
    the most popular of all seems to be the r4/r4i series.
    it is important to understand that these cards are not made by any one single company.
    this means that cards very similar in appearance, are in fact completley diffrent and require diffrent firmware for them to run.....
    it is very important when posting for help with these cards that you give as much detail about the card as possible.
    these two cards which look similar, are completly diffrent ,
    both have own firmware which won't work on other.
    please be as detailed as possible of what exactly is on the front of card.
    THE SD CARD:
    before you change ANYTHING on your sd card it is important to back it up.
    simply create a new folder on your desktop and drag/drop the entire contents of your sd card into it. this will help restore your sd card if things go wrong.
    most people (myself included) uses the windows formatter to format their sd card.
    it is recommended to use a formatting tool.
    i have uploaded a formatting tool for windows and mac.
    http://www.digital-kaos.co.uk/forums...ing-tool-1459/
    if would be worth backing up your card, then formatting and copying files back before asking for help.
    orginal r4 cards and their 1:1 clones do not support sdhc cards. if you are unsure whether your card is original, please use a 2gig card for testing purposes.
    once it's working you can try transferring to a bigger card.
    THE CONSOLE:
    it is important to know which console you are using and in the case of the dsi, which version firmware it is running.
    to check your dsi version:
    a. start up consoile without gamecard in.
    b. press settings.
    your console version will be displayed on top screen (bottom right hand side).
    GAMES(roms):
    when testing your card please use an old game, some cards are not so well supported and just won't play newer games....
    there are plently of older roms available.
    ADDITIONAL INFO:
    extra info can be helpfull.
    when did the card stop working?
    was anything done to card prior to problem?
    any updates done to card prior to problem?
    etc etc etc......
    TO RECAP:
    when posting for help include.
    a. card type with a detailed description including any web address found on card and if possible a picture of card.
    b. size of sd card.
    c. console you have and version firmware its on (dsi.)
    d. a full description of problem....
    e. if problem with specific roms, please post details
    also have a read through the section, chances are someone has had a similer problem.
    keep your firmware up to date.
    i post the latest unofficial firmware for acecards and original r4 cards.
    if you have these cards make sure they are up to date....
    http://www.digital-kaos.co.uk/forums...-users-169389/
    http://www.digital-kaos.co.uk/forums...rmware-175798/
    V.I.P. Member allycoops's Avatar
    Feb 2008
    Behind Enemy Lines
    Thanks Andy,
    Very useful guide, you might want to edit the link to the format software, it don't work the way it is Bud
    Let the others come after us, We welcome the chase
    scotland
    Quote Originally Posted by allycoops View Post
    Thanks Andy,
    done m8.
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Maybe we won't have to work to hard now andy
    scotland
    Quote Originally Posted by mickydibble View Post
    , that was the idea m8...
    doesn't seem to be working though...
    http://www.digital-kaos.co.uk/forums...e-noob-185572/
    DK Veteran reddevil157's Avatar
    Ireland
    nice one barrowman, and btw...... ye love all the questions !!!
    Top Poster worcestersauce's Avatar
    Nov 2008
    West Mids
    Do R4i cards work in the new nintendo DS XL ???
    Thanks in advance guys !
    scotland
    Quote Originally Posted by thenorthbank View Post
    yes,
    well sort of....
    depending on what r4i card it is and which version frimware your dsi xl is on....
    there has been two upgrades in dsi firmware, 1.4 and 1.4.1
    both these updates blocked flashcarts when introduced.
    so it depends on exactly which r4i card you have and also which version xl you have
    Nov 2008
    West Mids
    Thanks for the reply mate....bit confusing aint it ???
    So if i bought a brand new DS XL (still in box brand new) which would be the best card to get or could i use the R4i cards i already have and update them to work ?? (does that make sense)
    scotland
    , yeah thats why i dont use r4i cards....
    the simplest thing to do is buy an acekard2i.
    Acekard 2i 3DS | Acekard 3DS | AK2i 3DS | AK 3DS | Buy Acekard 2i 1.4.1 | Acekard 2 i | Ace kard | Acekard 2i Firmware
    a little bit more expensive than the r4i's, but they work in all dslites/dsi's and even reported working in the new 3ds. (with a card update)
    you see, with the acekard you have the abilty to update the card itself.
    i think this is possible with neweer r4i gold cards as well now.
    acekards also have the advantage of a "one size fits all" firmware, whereas r4i cards are all made by diffrent companies with there own firmware that dont work in each others cards.
    there must be at least half a dozen types of r4i gold cards which all look the same , but not compatible with each other.....
    have a look through the section m8, you'll see what i mean...
    Nov 2008
    West Mids
    Thanks Barrowman you've been most helpful
    Will just get the acecards for the kids save all the hassleand they're not that much dearer are they really ??....well worth it
    Thanks for the advice
    Apr 2011
    Co Durham
    Unhappy how do you get firmware (bits to set up your cards)?
    Thanks Andy,
    I have 1 R4i Card and 2 Acekards2 (one is an Acekard2i) I can't get them to work because I need the"bits" to go on my micro cards if I can't get the "bits" I want to get shot of these cards How can I sell them? do you want them? they are all new and in their boxes. I have just joined this sit & dont know how to use it. any ideas?
  13. #13
    Newbie Fitbafanatic's Avatar
    Jan 2012
    Thanks man, joined here tae get help and didnae even have to make a post, all info here and easy to use, Just remember to make a new folder called games in the rpg folder, easy as pie and very grateful.
    Thanks man
  14. #14
    Sep 2010
    Hi I have 2 R4 cards one is R4I in green writing its says 3DS the other R4i card says revolution for ds both of them are needed for 3DS, could you help me with the firmware plz.
    And another R4 card I have is for the DSI XL V1.4.1 this one is up and running, but some games dont seem to be showing after I have put them on, does this mean I have update it? If so how ? thank you, ur help is much appreciated
