Bouquets downloadable via Plugin or Script - Page 2
Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 107
  1. #16
    Sep 2010
    one of the guys posted his own script to do just this a while ago.
    check this thread.
    http://www.dreamboxuk.com/forums/showthread.php?1831-Script-to-Auto-Update-Bouquets-online.&highlight=script
    also check this thread
    http://www.dreamboxuk.com/forums/showthread.php?2239-Enigma1-Bouquet-Update-Plugin&p=9939#post9939
  2. #17
    Sep 2010
    ok first off i am not the author of this plugin, that honour goes to rossi2000 of DBUK. also i am posting this here in the DREAMBOX section but it will work with any E2 system.
    if you have any questions ask in a separate thread and reference this one and i will gladly pass them on for you. i will also keep this thread updated with future updates etc.
    Enigma2 Bouquet & Picon Update Plugin
    thanks to silverfox and google for the assistance
    transfer the attached file to /tmp/ and manuallly install it.
    the ipk will automatically reboot your box after installation, it will now appear in the plugins menu (green button)
    edit the .sh script in /usr/lib/enigma2/python/plugins/systemplugins/E2_Bouquet_Picon_Update with your file locations
    enjoy
  3. #18
    Sep 2010
    this ipk will check if youve installed the previous version, if so, it will remove it and re-install the plugin and place a new script in /usr/script. if not, it will install as normal.
    edit the .sh script in /usr/script with your file locations
    UPDATED 08022011:-
    cleaned the plugin directory of unneeded files, altered some code.
    the script has now been moved to /usr/script, any script updates can be applied to this file, no need to re-install the plugin.
    log file of bouquet updates created in /var/log
    enjoy
  4. #19
    Top Poster girovend's Avatar
    Sep 2008
    Anything for enigma 1 yet
  5. #20
    DK Veteran reddevil157's Avatar
    Ireland
    Hey lads, could you elaborate for the not so technical minded, from the, edit the .sh part plz.
  6. #21
    Sep 2010
    Quote Originally Posted by girovend View Post
    yes this.
    Enigma1 Bouquet Update Plugin
    this is easier to run the script, rather than having to go into the script panel.
    it will appear in the plugins menu instead now.
    transfer both files into /var/tuxbox/plugins
    chmod the .sh script to 755
    now in the yellow button you will see Enigma1 Bouquet Update. click it to update bouquets
    remember to edit your http file location in the .sh file.
  7. #22
    Sep 2010
    Quote Originally Posted by reddevil157 View Post
    open the .sh file with windows nopepad and look for this
    #Change the URL to point to your Bouquet zip file
    BQ="http://www.xxxx.co.uk/xxxx/enigma1.tar.gz
    change the url to the address where your hosting your .tar archive.
  8. #23
    Sep 2008
    I have updated the script
    no point in checking say everyday and downloading the same channels list, so a version check is done to confirm.
    The version check is a text file on the remote server with a number for version (incremental integer value) and also a local version on the dreambox.
    The script will download the version file from the remote server, check to see if the server version is higher than the local version and then only run the update script.
    as a test, the local version is 1 and the server version is 2 - thus it will pull down the latest update and also copy the new version file to /var/etc
    The version file is stored in /var/etc and must exist in order for the script to update. Hopefully further updates will include check for file to see if it exists and if not, then perform an initial channel refresh.
    #!/bin/sh
    # script to download latest channels lists
    # Tested on Enigma 1 images (DM500s)
    # Jfish 1 Feb 2011
    # change log
    # v1 - initial release (1 Feb 2011)
    # v1.1 - remove of reboot at the end of script - no need for it now (6 Feb 2011)
    # v1.2 - check for version update and only update if new version exists
    cd /tmp
    wget "http://192.168.1.10/remotever.txt"
    localv=`cat /var/etc/ver.txt`
    remotev=`cat /tmp/remotever.txt`
    if [ $remotev -gt $localv ]; then
    cd /tmp
    mkdir bq
    cd bq
    wget "http://192.168.1.10/bq.tar.gz"
    chmod 755 /tmp/bq/bq.tar.gz
    tar -xzvf bq.tar.gz
    rm -rf /var/etc/satellites.xml
    mv /tmp/bq/satellites.xml /var/etc/
    rm -rf /tmp/bq/satellite.xml
    cd /var/tuxbox/config/enigma/
    rm -rf *.tv
    rm -rf *.epl
    rm -rf *.radio
    rm -rf bouquets
    rm -rf services
    rm -rf services.locked
    mv /tmp/bq/* /var/tuxbox/config/enigma/
    rm -rf /tmp/bq.tar.gz
    rm -rf /tmp/bq
    wget -qO - http://root:dreambox@127.0.0.1/cgi-bin/reloadSettings
    wget -qO - http://root:dreambox@127.0.0.1/cgi-b...adUserBouquets
    rm -rf /var/etc/ver.txt
    mv /tmp/remotever.txt /var/etc/ver.txt
    else
    exit;
    fi
  9. #24
    nice way to check if downloads needed jfish, thx
  10. #25
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Can you show an example how the txt files look please?
  11. #26
    Sep 2008
    Quote Originally Posted by SGTFlipFlop View Post
    the version text file (which is what one assumes you mean) will have a number for example
    or
    or
    25
  12. #27
    Sep 2008
    another update done
    change log
    - functions added in code to make it easer to read and it goods programming practice
    - A check for local version file is done initially, if it doesnt exist - then get a copy of the channels list is downloaded and copy version file over from server to local directory. If local version file does exist, then check to see if a a more up to date copy exist on the server if it doest download and copy it otherwise do nothing
    here is the logic of the script...
    lets start by checking for local version file (/var/etc/ver.txt)
    if it doesnt exist then
    download channel and boquets and copy over to dreambox
    copy version file over to /var/etc
    exit as nothing else to do really
    but if local version file exist then
    if remote server version file is more recent than the local copy then
    if both version files are same then
    exist as nothing to do really
  13. #28
    Scotland
    See 3 people downloaded it without saying thanks, Bad patter.
    Excellent work again jfish
  14. #29
    Sep 2008
    I will be updating the script over the next few days.. I am going to get the script integrated into the Pli Jade 3 menu so can be called from box directly (as at the moment I run it via Telnet)
    may decide to host file on my webserver - so people who are using it can connect and download the boquets. May need to add some checking to ensure web server it available before performing the update.
  15. #30
    Sep 2008
    another update
    The script now check to make sure the server is online before performing the update.
    I tried to integrate the script into Open PLI image menu, but it was hanging so need to do some debug to find out
    also the script now connects to my server - therefore if you try it out yourself, it will connect to my server and download the channel list.
    At the moment only executed via Telnet which is not ideal.
    if anyone knows how to integrate the script into the Menu then I would like to know. As PPanel is giving me problems.
