Alternative GEMINI addon servers - Page 2
Page 2 of 6 FirstFirst 123456 LastLast
Results 16 to 30 of 79
  1. #16
    Feb 2011
    Is it working on dm7020 gemini 4.7 ?
  2. #17
    Feb 2011
    Nice one ! Thank you sir ! going2 check this out 2morrow.. Do you know which prog i can use if want 2 recording? Is there a backway? I got the dm 600pvr..
  3. #18
    Feb 2011
    sorry to sound like a complete noob...but i can't seem to find the var/ tuxbox/ config directory. My tuxbox folder is in etc/ tuxbox/ config and the only file inside is a enigma 2 file which takes me somehwere else altogether. Am i missing something?
    ps i am using gemini 4.70 on dm 800 hd pvr 2.01 sim bl76 m tuner.
  4. #19
    Quote Originally Posted by bumbola View Post
    had the same issue theres an exiting file in tuxbox (from memory, would check but doing a refresh).
    Originally did an overwrite which lost the www.example. then adjusted the orginal manually, did a url at a time.
    Only issue is I get "error 12 - unknown error" been playing the the last 20 hours trying to get cccam installed. On the 4th image, fingers crossed
  5. #20
    dm500hd gemini e2 5.0 not working
  6. #21
    Feb 2011
    i have a dreambox 500+ and i found the useraddon.xml at directory /etc.
    i put the links in this file and working all fine except the two last links.
    nice job.
  7. #22
    Feb 2011
    Quote Originally Posted by deffc0n View Post
    All cams and many many more
    Work test 100%
    Install for BP and restart and go to plugins.
    working this in dreambox 500+;
    if working, how i can put it and install it;
    P.S. i put the ipk file in the directory /tmp but i can't see in the list
  8. #23
    Feb 2011
    hi to you all, im pete keep reading about all the boxes and stuff, iv got the starview combo 4 my sins, yhe thing is i dont understand any of it, can anyone tell me how to get a box where it is ready to go, all i have to do is plug in, cab, or dish ? thanks a verry thick yorkshire man.
  9. #24
    Mar 2011
    Does it work with GP3?
  10. #25
    Mar 2011
    thxx evebody work for me
    dreambox dm500s with gemini 4.70 maxvar !! Enigma 1
    The last two doesn't work for me , it says url has been permantly moved :s
  11. #26
    Apr 2011
    hmm. i get the servers to work. but getting an error when tryig to download.. any solution on that issue? i have DM500HD
  12. #27
    Apr 2011
    Post Gemini Server Addons problem
    How can I manage to find addons for my DM600. There are 0 to find when using blue panel.
  13. #28
    Apr 2011
    try this one on gemini 4.7...thanks
  14. #29
    Apr 2011
    I will try this and see if it works on old gemini 4.4
  15. #30
    May 2011
    what about dm500s is possible to use gemini
