Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 79
  1. #31
    May 2011
    Did anyone test this with Gemini iCVS for 500HD and if so, did it work?
  2. #32
    May 2011
    thx for this
    Quote Originally Posted by Flashing-Dude View Post
    Everybody knows that the IHAD 22.01.2011. The ability to shut down direct download from a server in Gemini DreamBox receivers. Manually inserting the DreamBox can be hard (if it brings in more receivers simultaneously) as well as changing file permissions and so far it was all automatic odradjivano direct download. E and it has come to an end with the alternative URLs for download CAMs from different servers.
    The working principle is very simple and below the URLs entered in the path var / tuxbox / config / useraddon.xml that you previously copy to the HDD from the computer (I suggest the simplest FillaZilla Client FTP manager) and the same open with Notepad + + or Wordpad and copy / paste URLs.
    Upon completion and save the file back to the same location in the Dreambox and that the var / tuxbox / config /.
    Added alternate servers is located on my servers to download them arriving by clicking on the blue button on the remote -> Addons (option 2) -> OK
    These servers are included...:
    <item name="Dream Devils Server" url="http://www.moonbeamonline.com/dd/addon_server/ddserver.xml"/>
    <item name="HackSat Addons 1" url="http://www.dvbfiles.com/camd/cam40.xml"/>
    <item name="HackSat Addons 2" url="http://www.uydu.ws/camd/cam40.xml"/>
    <item name="Luxsat 4.0" url="http://www.luxsat.eu/hpengine/download_files/luxsatcam4.xml"/>
    <item name="Imajteam-Server" url="http://www.forumimaj.com/dreambox/addons.xml"/>
    <item name="Gold Panel" url="http://www.turkdvb.com/dreambox/server.xml"/>
    <item name="Sat-4-All" url="http://www.sat-4-all.com/portal/plugins/addons.xml"/>
    <item name="ID-Server" url="http://members.vol.at/easynet/gemini_server.xml"/>
    Found this laying around ..... use at your own risk, but should be legit...... ( haven't personally tested as i don't use GEMINI )
    Please reply with info about if it's working or not working....
  3. #33
    Jun 2011
    hi.are these links alternative for cam and cam conf ?
  4. #34
    Jun 2011
    Default Alternative GEMINI addon servers
    hi all
    im new to db....plese tell me
    how to use these on dm500s?
  5. #35
    Jun 2011
    im not able to connect to any servers... i have two showing on ccc info
  6. #36
    Top Poster domirudi's Avatar
    europe
    what kind of image do you recomend?
  7. #37
    DK Veteran deffc0n's Avatar
    UK/POLAND
    New link here:
  8. #38
    Aug 2011
    Can anyone confirm if this works in GP2
  9. #39
    Aug 2011
    Are these Servers still active?
  10. #40
    Aug 2011
    Thanx for detailed and very helpful description of how to expand addon-serverlist. :-)
    It worked perfect for my GP4.70, even if some of the servers in the initial list are now in-operative... Thanx again! :-)
  11. #41
    I tried to download cccam from gemini server like i did a year ago but now it seems to be deleted. Does anyone know why, or maybe where can i find cccam 221 ?
  12. #42
    Aug 2011
    Is it possible, that the correct directory is now /etc? Only there I can find the file useraddon.xml. I own a DM800 (E2) with Gemini 5.1. If I put the downloaded file into this directory, there are no more servers than the original Gemini Download Server choosable in the Blue Panel.
    Have you got any ideas?
    Thx & Greetz,
    XStoneX
  13. #43
    Aug 2011
    does it work with dm 7000
  14. #44
    Sep 2011
    at gemini 4.2 where i can find useraddon.xml ?
  15. #45
    Quote Originally Posted by pappas11 View Post
    var/tuxbox/config
    i have just replaced my useraddon.xml file with the one posted in the first post and some work and some don't but from the ones that do work you can get most cams etc that are missing from the gemini servers
