Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 79
  1. #46
    Sep 2011
    DM500s. Does it work with this?
  2. #47
    Sep 2011
    Default DM500s
    Hi ,
    I downloaded the pload file and ftp'd it onto the correct folder on the box.
    I downloaded the ccam 2.09 file and the ccam 2.09 cfg file and they installed perfectly. I edited the ccam.cfg file and rebooted the box. But the commom interface loads all the time instead of the ccam. Any ideas of what ive missed here?
    ta
  3. #48
    Sep 2011
    does this work on dm7000
  4. #49
    Sep 2011
    Quote Originally Posted by Flashing-Dude View Post
    The working principle is very simple and below the URLs entered in the path var / tuxbox / config / useraddon.xml
    Thanks for your advice, Dude, but I somehow can't detect where I should put these URLs on my Dreambox 7020, Gemini 4.6? Bluepanel Addons...download(myserver) writes "error:server replied 302 Found (URL:http//www.example.com/test.xml). I cannot detect where that URL (in form of some *.xml) is in Dreambox tree. Certainly not in var/tuxbox/config.
  5. #50
    Sep 2011
    entereter on dm7000 but still not working as it still comes with the old i have a dreambox server not found please help
  6. #51
    Sep 2011
    can i use this on db7000
  7. #52
    Jan 2011
    Does this work for DM800-SE? or is it for all versions of the DM?
  8. #53
    Question
    only 1 or two hosts are working it is very old now that useraddon.xml ..i was kinda hoping by now that a new more uptodate Useraddon.xml can be found for my dm600s pvr ??? it wud be nice if someone can help with that ??????
  9. #54
    toysoft's Avatar
    Nov 2008
    I use "Ferrari Addon Manager" and works great, you can find it with google to download the ipk to install.
    TS
  10. #55
    Default anoder 2 addons server
    <item name="Midar_sat_ Server" url="http://www.moonbeamonline.com/dd/addon_server/ddserver.xml"/>
    <item name="Midar_sat_ Addons" url="http://www.dvbfiles.com/camd/cam40.xml"/>
    add to useraddon.xml in /var/tuxbox/config
    tested whit Gemini4,2 E1 DM500S - ok
  11. #56
    Dec 2011
    Thanks. How do you know you gemini version ?
  12. #57
    Dec 2011
    Quote Originally Posted by deffc0n View Post
    All cams and many many more
    Work test 100%
    Install for BP and restart and go to plugins.
    Workin in GP3 ?
  13. #58
    Oct 2011
    Hi i?m a bit new at this but i put in the alternativ servers i my db500 via putty and but they don?t appear in the blue panel/addons?
    Please " get guidance
    Ambessa
  14. #59
    Dec 2011
    I got the same error : server replied 302 found
    any help ?
  15. #60
    Jan 2012
    Is it working on DM800 with GP3?
