Nice one ! Thank you sir ! going2 check this out 2morrow.. Do you know which prog i can use if want 2 recording? Is there a backway? I got the dm 600pvr..
sorry to sound like a complete noob...but i can't seem to find the var/ tuxbox/ config directory. My tuxbox folder is in etc/ tuxbox/ config and the only file inside is a enigma 2 file which takes me somehwere else altogether. Am i missing something?
ps i am using gemini 4.70 on dm 800 hd pvr 2.01 sim bl76 m tuner.
had the same issue theres an exiting file in tuxbox (from memory, would check but doing a refresh).
Originally did an overwrite which lost the www.example. then adjusted the orginal manually, did a url at a time.
Only issue is I get "error 12 - unknown error" been playing the the last 20 hours trying to get cccam installed. On the 4th image, fingers crossed
dm500hd gemini e2 5.0 not working
i have a dreambox 500+ and i found the useraddon.xml at directory /etc.
i put the links in this file and working all fine except the two last links.
nice job.
hi to you all, im pete keep reading about all the boxes and stuff, iv got the starview combo 4 my sins, yhe thing is i dont understand any of it, can anyone tell me how to get a box where it is ready to go, all i have to do is plug in, cab, or dish ? thanks a verry thick yorkshire man.
Does it work with GP3?
thxx evebody work for me
dreambox dm500s with gemini 4.70 maxvar !! Enigma 1
The last two doesn't work for me , it says url has been permantly moved :s
hmm. i get the servers to work. but getting an error when tryig to download.. any solution on that issue? i have DM500HD
How can I manage to find addons for my DM600. There are 0 to find when using blue panel.
try this one on gemini 4.7...thanks
I will try this and see if it works on old gemini 4.4
what about dm500s is possible to use gemini
