Page 1 of 6 123456 LastLast
Results 1 to 15 of 79
    Junior Member Flashing-Dude's Avatar
    Default Here is alternative GEMINI addon download servers
    Everybody knows that the IHAD 22.01.2011. The ability to shut down direct download from a server in Gemini DreamBox receivers. Manually inserting the DreamBox can be hard (if it brings in more receivers simultaneously) as well as changing file permissions and so far it was all automatic odradjivano direct download. E and it has come to an end with the alternative URLs for download CAMs from different servers.
    The working principle is very simple and below the URLs entered in the path var / tuxbox / config / useraddon.xml that you previously copy to the HDD from the computer (I suggest the simplest FillaZilla Client FTP manager) and the same open with Notepad + + or Wordpad and copy / paste URLs.
    Upon completion and save the file back to the same location in the Dreambox and that the var / tuxbox / config /.
    Added alternate servers is located on my servers to download them arriving by clicking on the blue button on the remote -> Addons (option 2) -> OK
    These servers are included...:
    <item name="Dream Devils Server" url="http://www.moonbeamonline.com/dd/addon_server/ddserver.xml"/>
    <item name="HackSat Addons 1" url="http://www.dvbfiles.com/camd/cam40.xml"/>
    <item name="HackSat Addons 2" url="http://www.uydu.ws/camd/cam40.xml"/>
    <item name="Luxsat 4.0" url="http://www.luxsat.eu/hpengine/download_files/luxsatcam4.xml"/>
    <item name="Imajteam-Server" url="http://www.forumimaj.com/dreambox/addons.xml"/>
    <item name="Gold Panel" url="http://www.turkdvb.com/dreambox/server.xml"/>
    <item name="Sat-4-All" url="http://www.sat-4-all.com/portal/plugins/addons.xml"/>
    <item name="ID-Server" url="http://members.vol.at/easynet/gemini_server.xml"/>
    Found this laying around ..... use at your own risk, but should be legit...... ( haven't personally tested as i don't use GEMINI )
    Please reply with info about if it's working or not working....
    Last edited by Flashing-Dude; 26th January, 2011 at 08:41 PM. Reason: edited title
  2. The Following 2 Users Say Thank You to Flashing-Dude For This Useful Post:
    toros42 (2nd December, 2013)
  3. #2
    Im useing dm500s Image Gemini 4.20..
    It is possible to add this serve to gemini 4.2 Image?
    If possible please Guide me how to Add serve to This Image
    Wich folder
    Member naveed1111's Avatar
    Sep 2008
    Tested on DM 500s ...Gemini 4.2...
    Works As Treat..
    Great Work..Thanks for Sharring
    May 2009
    Default Gemini addons
    Is there any possibility to have gemini addons from Gemini server ?
    May 2009
    Default Alternative GEMINI addons
    All working Fine Thanks m8, Do U know if there is any possibility to have back Gemini addons on dramboxes??
    Jan 2011
    accept for last two link?s, works fine on DM600.
    but how to add them to gp3?
    Apr 2008
    Quote Originally Posted by TimeWheel View Post
    Try this for gp3
    Jan 2011
    Are there any differences in adding an additional addon server between GP2 and GP3.. cant get it working..
  10. #9
    Jan 2011
    This is translated from serbian? What forum ?
  11. #10
    Jan 2011
    is this for he 7020 if so where do i ut them ive tried var tux config , i get error server replied 302 found url www.example.com.xml
  12. #11
    DK Veteran deffc0n's Avatar
    UK/POLAND
    All cams and many many more
    Work test 100%
    Install for BP and restart and go to plugins.
  13. #12
    Feb 2011
    Has anyone tested it in the latest Gemini 2 version?? (think it was 5.1)
  14. #13
    Aug 2010
    thanks for all
    it's ferry good
    i test in Gemini 470 it's works
  15. #14
    Aug 2010
    now i put in my server for all addon
    so i make mirror for all addons
    thanks again for it
  16. #15
    Feb 2011
    Default Not workin for GP2 5.1
  17. The Following 2 Users Say Thank You to shadowman86 For This Useful Post:
    pepe75 (29th July, 2013), snolzer (11th June, 2014)
