Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 140
    Default peugeot boxer immo
    hi guys
    I have problem with immo on this ecu from boxer :0281 010 346 edc 15c7.engine 2.0hdi
    I tryed disable immo on flash 29f400 but engine dont start.
    Im not sure if the file is readed well.Maybe is my file corupted.
    when I put my file (immo off) the ecu have wrong ident.and
    engine mil lamp is disbled (dead)
    After that I tryed with file from jumper with same bosch number
    and ecu work ok but engine dont start.Mil lamp is on and
    eror is ecu bloked from immo.(immo active)
    Please, did someone can check my file or any solution for disable immo.
    THANKS for help
    here is all three file
    DK Veteran sl4ck's Avatar
    Immo off is on 95p08 not flash
    KTAG, PCMFlash, Galetto FGTech V54, Smok Multitiool UHDS, I/O Terminal, Fiat/Alfa IAW Bosch Decoder, UPA-USB, XPROG, FVDI, Orange5, Renolink, DiagBox, Can Clip, Xentry
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    This is EDC15C7. Immo is in flash. I don't have access to my lapy to modify. In 2-3 hours i will help you.
    Busswil Switzerland
    youare file is corupted, you need virgin file for immo box.
    Quote Originally Posted by lupu_sandu View Post
    Lupu i?m not sure, but i think ...345 and ...346 can be off on 95p08, ...484 don?t
    As i said, not sure...
    You?re right Lupu, checked it right now, can?t immo off on 95p08, at least ECU with 3 blue condensers side by side near the plug.
    There s another with condensers not side by side
    lupu_sandu's Avatar
    In my immobox...
    Your immo off file (chksum OK):
    PS: Your file orignal was :boxer org edc15c7 immo on.bin:
    Lupu: what software do you use to correct checksum?
    lupu_sandu's Avatar
    In my immobox...
    sl4ck: With checksum corector (is posted on DK).
    carbyvw: If you need help and ask, why you don't try files if anyone try to help you?
    You say that your file is like mine. Witch one?
    SCP decoding boxer org edc15c7 immo off.bin - don't have checksum and is modified only in two places.
    JUMPER hdi-277-346.dat.bin - is from another ECU
    Your ECU is: HW: 0281010346 SW: 1037351989
    hdi-277-346.dat.bin: HW: 0281010346 SW: 1037369277
    So, my friend, next time when you scream for help, maybe you can respect others members work.
    No one ask anything in return, just a little respect for our work.
  10. The Following User Says Thank You to lupu_sandu For This Useful Post:
    jomberykaso (17th April, 2019)
  11. #10
    lupu_sandu: can you help me immo off my flash?
  12. #11
    I'm sorry lupu, you're right.I did not look good your file.
    thank you very much.Tomorrow I will try on the car and send you results.
    once again I'm sorry and thank you
  13. #12
    lupu_sandu's Avatar
    In my immobox...
    Quote Originally Posted by sl4ck View Post
    Your file off m8:
  14. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    estwood68 (21st May, 2019), missfixit (20th February, 2017)
  15. #13
    hi
    this fckuing engine dont start
    immo is still active (dtc u1600- code not recived)
  16. #14
    lupu_sandu's Avatar
    In my immobox...
    MIL will be on. Error code will be present, but engine must start.
  17. #15
    Oct 2008
    heaven
    Quote Originally Posted by carbyvw View Post
    hi
    are you remove immo box..yesterday i try same car ducato 2.0 and same ecu no problem..i write 29f400 immo off flash and remove immo box car start maybe your problem different solution %100 working
