Page 2 of 8 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 110
  1. #16
    DK Veteran tomaszcz's Avatar
    ZGP
    Theline K pin 9 - only diagnosis
    Theline Can-bus pin 1 & 2 - reset immo this line
  2. #17
    damih's Avatar
    france
    Hello,autodiags20 can you explain more how to read this eprom SDA i try it without result
  3. #18
    Hungary
    autodiags20
    Do you know which bytes in the eeprom what does it mean?
    The first 64 bytes of the fault memory. The rest do not know.
  4. #19
    Mar 2009
    NorthPole
    is it enough to connect +12V, GND, IGN to PSG5, connect SDA, SCL to programmer and read which type of eeprom?
    24C ??
  5. #20
    Lithuania Taurage
    Quote Originally Posted by bani View Post
    24C ??
    sda eeprom like 24c04
  6. #21
    Lithuania Taurage
  7. #22
    damih's Avatar
    france
    Hello,ok for rx and tx but vss and vdd 5v ???
  8. #23
    Lithuania Taurage
    rx tx, vss psg5-6, 12+-psg5-7 5v not need
  9. #24
    damih's Avatar
    france
    Ok thanks autodiags20
    " rx tx, vss psg 5-6, 12+-psg5-7 5v not need "
    in connecteur (plug) of driver
  10. #25
    Slovakia
    Quote Originally Posted by tomaszcz View Post
    I agree.Bosch can do this no problem.
    How with KTS? I?have nothing in menu....
    only identification, read fault codes,delete fault codes?
    KTS 540 + latest soft...
  11. #26
    NO simulation KTS connect to pump
  12. #27
    ZGP
    Quote Originally Posted by erikfrog View Post
    Connect k line and can bus. Kts menu adaptation pump and wait 15min.
  13. #28
    Slovakia
    Will try it. Because I, have tested also with pump in car and KTS connected to OBD in car. The same result.
    So KTS direct to pump?
  14. #29
    KTS direct to pump
  15. #30
    ALGERIA
    but you forgot pin3 ,must connect this pin to autorise the immoreset
    the probleme that i don't know it number in pump's conector
    someone know what's his number on pump's connector?
