Page 7 of 8 FirstFirst ... 2345678 LastLast
Results 91 to 105 of 110
  1. #91
    Oct 2016
    Quote Originally Posted by niki85 View Post
    here you are
    regards
    Thank you So Much
  2. #92
    Oct 2011
    So what? Can i use focom (clone) to resset the focus vp30?
  3. #93
    Nov 2016
    Hello. Or tell someone how to read eeprom from pSG5 with carprog 4.01? I have only " 0000"
    connect sda/scl/vcc/gnd.
    any ideas?
  4. #94
    Aug 2015
    Cool
    Bosch KTS can do adaptation without any problem. Need direct connection Can, k-line and power. 5 pins. With k-line possible just read and clear errors. For adaptation need K-line and CAN!. Open PSG5 adaptation in easy tronic, press F2 and wait 900sec. If process stops in 880sec look connection of CAN wires and restart.
  5. The Following 2 Users Say Thank You to chippirate For This Useful Post:
    jackeldestripador (26th December, 2016), lossis (22nd February, 2021)
  6. #95
    Feb 2016
    Where can I find this connector?
  7. #96
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by AREA22 View Post
    Make one yourself.
    Very easy
  8. #97
    Feb 2016
    I need the schema and the emulator to do it, i mean the companion cable aktiv22
  9. #98
    Feb 2016
    you know if with the Chinese VCM cable you can pair the VP30 to a Focus 1800 Tddi, thanks
  10. #99
    Feb 2016
    In the end I was able to pair with a Chinese cable off the ancients, thanks to all.
  11. #100
    Feb 2016
    In the end I was able to pair with a Chinese cable of the ancients, thanks to all.
  12. #101
    Jan 2016
    please activate
    R160385679
    6373-4BAD-11DE-C0CC-DEDA-0E4D-92DC-4887-74E6-0EC8-53E1-DD26-D087-6802-4EA8-7A0A
  13. #102
    Sep 2019
    Hey,
    I found a dealer who sells PSG5 units. They also have a EPS 815 test bench.
    Is there a way to reset to virgin status with the EPS 815?
    My dealer told me that he isn't able to "delete the immobiliser". "They only test the PSGs". I guess that he doesn't know how to make the reset.
    Now I need your help. If a reset is possible with the EPS 815, I need a "step by step how to". That would allow me to explain him the steps.
    Is the reset a ford specific thing or does it work with the PSGs of all brands?
    I thank you in advance.
  14. #103
    Mar 2017
    France
    Dear Dks
    Do you knew how to adapt send hand vp44 ford pump (ford fucus 2003) using launch or forscan???
    Thanks in advance
    Regrads
    Envoyé de mon iPhone en utilisant Tapatalk
  15. #104
    toyota123's Avatar
    Sep 2019
    Question PSG5 VIRGIN IMMO OFF ? help?
    hi mates i have repaired PSG5 on ford connect , i connect the BOSCH KTS 520 to PSG5 head unit directly with the connections in images , and this is what i get in pictures.(i also deleted the Error Memory,the DTC's successfully deleted).
    So now i need to make the unit VIRGIN to equip it on another car same year , i read and asked many times that the BOSCH KTS can do it , now i need to know this ADAPTATION operation that shows in last image , is it the same thing with make the Head Virgin (IMMO OFF) or not ???
    if someone does it before with this method please share informations(HELP)
    thanks in advance , best regards for help
  16. #105
    F2 START ADAPTATION AND PSG VIRGIN
  17. The Following User Says Thank You to janusz21 For This Useful Post:
    toyota123 (13th January, 2021)
