Page 8 of 8 FirstFirst ... 345678
Results 106 to 110 of 110
  1. #106
    toyota123's Avatar
    Sep 2019
    Quote Originally Posted by janusz21 View Post
    F2 START ADAPTATION AND PSG VIRGIN
    so it will do immo off and after that i can equip it on different car ?
  2. #107
    NO immo off only virgin
  3. The Following User Says Thank You to janusz21 For This Useful Post:
    toyota123 (14th January, 2021)
  4. #108
    toyota123's Avatar
    Sep 2019
    thankssss , it’s always nice to have mates like you .
  5. #109
    toyota123's Avatar
    Sep 2019
    hi mates i have another psg5 head vp30 on perkins , is it need to be virgin like ford or not nessessary ?
  6. #110
    Nov 2018
    3 floor on Red Dwarf
    Hi bro, i will you litlebit explain what is what a maybe this help you or someone else too in future.
    When you doing ecu in immo off mode then you may use it on any car where is this ecu compatible without any next prepare for use it, because ecu in this mode ignores engine stop packets from immo system your car and start and of course run engine is allowed anytime when or where you want.
    When you doing ecu in to virgin mode then you have ecu prepared for learn immo packets for first start on your car after you changing your virginized ecu. This procedure is fully automatic, only conecting to car and when you up ignition then ecu relearn immo packets with car and after that only in this car where ecu is adapted you may allowed start and run your engine. In case if you want use this same ecu on next one car then you must again set ecu on virgin mode before installing it on another car and again doing automatic relearn procedure after first time you set up ignition on car.
    Thats all, i hope it help. If yes please thanks.
    Petr
