Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 110
    DK Veteran tomaszcz's Avatar
    ZGP
    Default VP44 pump ford immo
    Does anyone know how CLEAR immo ford pump VP44?
    Jun 2009
    interesting
    ZGP
    Quote Originally Posted by amaflo View Post
    interesting
    I found this
    there is an electro vale which regulates and stops fuel pass. It has one cable, remove it and replace it with a normal one, with no cable.
    ussualy it involves taking the pump out
    Top Poster bekamon's Avatar
    Mar 2009
    Quote Originally Posted by tomaszcz View Post
    I found this
    what is this
    damih's Avatar
    france
    Hello,i have a same problem how to reset a VP 30 for ford ?
    with IDS ?
    Default vp30for ford
    Quote Originally Posted by damih View Post
    with IDS ?
    HI
    1 Start IDS software
    2 Modul programing funcion
    damih's Avatar
    france
    Hello,Igor but i don't have IDS
    treo's Avatar
    R
    Quote Originally Posted by ominimicu View Post
    In vp44 pump is 2 actuators,one for fuel quantity,one for advance,so you can not replace one actuator with single wire valve.
    if you have a bosch kts interface and a cable to conect to the pump control unit in 15 min. solved
    KTS can do it this. You must connect pump by universal cable to KTS (PSG5) and next reset in Diagnosis -Ford-PSG5 this unit
    DK Veteran zoro1's Avatar
    Bulgaria,Sofia,Vidin
    With IDS and some software like Criptoworks.IDS give to you incode ,when you type incode in crypto soft there is generating outcode.
    Large nations behave like gangsters ,and young as prostitutes !
  13. #13
    ZGP
    Quote Originally Posted by barichelo View Post
    I agree.Bosch can do this no problem.
  14. #14
    Lithuania Taurage
    read sda eeprom in psg5
  15. #15
    ZGP
    Quote Originally Posted by autodiags20 View Post
    How read eprom?
