my dear friend
The guy who asked for support was asking for solution to revival the tool - not the sw.
What you have uploaded it is the original sw nothing else more. For him support he needs program the uC proper.
As far as I read / know there is no solution only by sw to stop the counter, unless maybe you know something which I do not know and I would like to know from you if there is such solution!!!??
Just for the record: you have uploaded original sw not sw with solution for counter stop/revival.
Counter is disabled in the mpps cable not software
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Slipah (4th June, 2013)
as I said - the solution it is in the fw written into uC not into the sw, as far as I know / read.
atb
Hello all. I have an ex mpps v3, which due to wrong update with a V8 version of the original, is now dead. Let me explain, is that is not recognized, but in device manager, instead of appearing as amt flash, appearing as a peripheral interface uman, so with any version you want to update, is not seen no device. Can you tell me please how to restore it?
Can somebody share a uC dump?
did you solved this?
Any solution on MPPS V18 ECU NOT FOUND?
every car edc16u1 edc16c and etc
Dear Friends,
I need for MPPS V16 clone - schematic.
This are the IC chips inside:
U1 - C8051F340 - Full Speed USB Flash MCU Family
U2 - SJA1000T -- Stand-alone CAN controller
U3 - C32R -- voltage regulator 3,2 Volt - ST LDK130C32R
U4 - А1040А = TI SN65HVDA1040A-Q1 EMC-Optimized High-Speed CAN Bus Transceiver
U5 - E5R -- ???
U6 - empty
U7 - 8S103F3P6 -- MCU STM8S103F3
U8 - L9613 -- Data interface / 8 pin
I have problem with the wrong voltage.
My MPPS V16 show aprox 30 Volts. This is not real.
I think that my problem is with wrong or not correct resistors.
Please post here schematic or/ and PCB for MPPS V16 clone. Many people will be happy!
Thank you! Sorry for my bad English!!!
