Page 3 of 141 FirstFirst 123456781353103 ... LastLast
Results 31 to 45 of 2103
  1. #31
    May 2010
    Please help with pin for FIAT ulisse 99 2.0 8v ZFA22000012523821 Thanks!
  2. #32
    gokey's Avatar
    Feb 2010
    Quote Originally Posted by pelot View Post
    Please help with pin for FIAT ulisse 99 2.0 8v Thanks!
    Pin Code: J99K
  3. The Following User Says Thank You to gokey For This Useful Post:
    antonypaul (6th June, 2022)
  4. #33
    DK Veteran fifas2010's Avatar
    Sep 2010
    in the midst of war
    Default UCH
    Please i need the pin code to this UCH
    BR
  5. The Following User Says Thank You to fifas2010 For This Useful Post:
    bonifanc (16th October, 2013)
  6. #34
    Sep 2010
    in the midst of war
    Default uch
    Sorry,and to this one ):
  7. The Following User Says Thank You to fifas2010 For This Useful Post:
  8. #35
    gokey's Avatar
    Feb 2010
    Quote Originally Posted by fifas2010 View Post
    Pin Code: A50DC30BDF3F
  9. #36
    Member islam kadah's Avatar
    Feb 2010
    Pin Code: 7D0880F1AC3F
  10. #37
    Feb 2010
    BR
  11. #38
    DK Veteran Poptest's Avatar
    Sep 2010
    Default Pin codes
    I'm quite new to this topic about pin codes.
    Can someone please share what pin codes mean?
    Thank you in advance.
  12. #39
    Jul 2010
    Quote Originally Posted by Poptest View Post
    friend , we are doing tests with zed bull, and we are helping friends with pin codes free, if you need pin code read the dump and post here, we have some pictures of immo and modulo so check the picture , thanks
  13. #40
    Jul 2009
    Busswil Switzerland
    Default immo box simens vw
    Here is the dump with pin .
  14. #41
    Jul 2009
    Busswil Switzerland
    Default reno megan 2
    reno megan 2 hc912
  15. The Following User Says Thank You to Babanovski For This Useful Post:
  16. #42
    DK Veteran teuton's Avatar
    Nov 2009
    Mexico
    Pin code means a combination of numbers and/or letters you need in order to perform some special functions like key learning, swapping (exchange) carcomputers, dashboards and to do adaptations/programming.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  17. #43
    Sep 2010
    Default 2007 Chevy Captiva Immo problem
    Thank you for your posts/replies. I'm really new to this field, and starting from zero.
    I have a Chevy Captiva 2.0 common rail diesel with an immobilizer problem which I would want to fix.
    I only have Launch 431 and Bosch KTS. But most people say that I need Tech2. Do I need additional hardware and software? How do I get the pin code and put it in?
    Thanks much.....
  18. #44
    Top Poster autocrypto's Avatar
    Jul 2010
    Default Pin for Fiat Grande Punto
    Hi people,
    Can any one give me the pin code for this Fiat Grande Punto and please tell me where is the location in bin file.
    Many thanks in advance
    Best regards,
    AutoCrypto
  19. The Following User Says Thank You to autocrypto For This Useful Post:
  20. #45
    Nov 2009
    celje, slovenia
    hello i have read ecu pasat (1.8t y 2004) vith vag dash com can and it wrote that pin is 7815 but this pin is not accepted by controler so can anyone check what is right pin from this dump chasis nr is: wvwzzz3bz4e319492, and can someone calculate me a 7 digit pin code and workshop code, becouse vas says only 7 digit code can be accepted
  21. The Following User Says Thank You to diga1 For This Useful Post:
